sir you sure talk a lot of trash about stuff you don't know. you obviously can't hack a 110v welder (i can weld 1/2"steel with it and HOLD...ask several customers..one who has been towing his fith wheel for ohh....6years now and that fith wheel plate holding up perfect...2.should've seen Madjeepj10 pound his MJ face first down Laurel lane after loosing his brakes at the top and HOLY HELL...factory brackets ripped off axles and body and guess what...ALL my links, brackets and such on unibody and axles held up perfect with NONE stress cracks. You like most say 110v welders suck...that's just cause you probably started out with 220 and can't work these little guys but a 110 with .35wire done properly can burn 1/2" steel no problem and 5/16" is nothing for it. and again, you don't like my "good enough for me" cage...beat it pal. It's not your rig, your life, or your head so the hell do you care..and BTW we're not wheeling in the "rockys" for crying out loud...we're at the flats and most of what hills "I" would/will be hitting are more than safe enough for my Jeep and My cage to handle.
the sch40 stuff:...my local steel shop whose been in business for ...ohh 25+years says for what i need and do, that stuff holds up no problem for cage material and told me it might "dent" a little quicker than DOM but will hold up....especially when braced properly which mine isn't yet but it's close enough for now and will be finished so you can argue about these stupid pipes all you want but remember something...people have built trucks and buggies and cages for a whole lot less before all our time and they lived and survived ....and I've rolled a Jeep down a bank 3times when drunk long long time ago and survived that pretty well with NOTHING but factory sheet metal.
yes i can build hitches, cages, arms, brackets, crossmembers and i can even properly weld to axle housings...whoop whoop. "Just cause my jeep is ghetto does not represent my work capabilities dude, get real already. You haven't learned in all these years that my jeep is the "leftovers" of finances and materials. My wife, daughter, house, family DD and bills are priorities...what little is left goes in this pile of metal that has taken me places everyone doubted and will continue to do so for long long time.
I would put my XJ with all the frame plating and boxing and rock rails and cage and flat bottom and more bracing...ALL WELDED TO THE UNIBODY...against ANY...ANY...properly caged XJ in a 500ft roll and would bet my whole shop equipment it would hold up and not break apart in any section. Will I? NO cause i'm not engaging in proving anything to people like you but just showing the confidence "I" have in my work and it has proven for me and many many people that are normal...unlike the "pro"fessionals like yourself claiming you can't use 110welder for 5/16??? yeah i trust a Pro who can't weld with 110welder...no thanks, I'll stick to what i know and what i know best.
