sounds good man! cant wait to see this thing in actionInterior cage for sure. it'll be a simple 8 point cage. I'm going to start accumulating tubing in the next few days.The seats will be mounted directly to the cage and I will tie in the cage to the frame at 6 of the 8 points. I want to build the cage before I add the sheet metal to the floor so I can drop the cage down through the floor to weld the top of the cage bars. I thought that would make it easier and cleaner than drilling a bunch of 1.75" holes in the floor to drop the cage down to weld them up.
Impressive work man, love the look of the squared off roof on that thing.
If not, I'll plate the inside of the framerails at the rear spring perches and add bracing at the rear of the frame using some 1.75" tubing I have laying around.Short update: I ordered 30ft of 1.75" .120 wall DOM tubing from Barnes 4wd. I'm hoping it comes in today so I can get started on the roll cage this weekend.If not, I'll plate the inside of the framerails at the rear spring perches and add bracing at the rear of the frame using some 1.75" tubing I have laying around.
Chad,
FedEx says that it is on the truck for delivery!
Thanks for your business
Brad
Ive got to stop by and check this out someday....since you live in my neighborhood! looks great!![]()
Good job , I like all the oroginal work . One of a kind.![]()
Congrats on the JP magazine coverage. Just went through the whole thread playboy style(pics) ....looks like you have your welder all figured out. Keep up the good work.
Been following this since page one and it's coming together awesome. That looks like the same fuel cell I'm looking at putting into the back of my Samurai. 30"x9"x12" right? Do you like how it's built? I may go with the 17" high, 7" deep one. Depends on how much 2" is going to affect how my back seat is going to fit. Keep up the good work!![]()
This thing is coming together quick, when is it going to be wheel-able, or when are you shootin for it to be wheel-able?
Mount the door bars flat/straight and adjust the seats with the mounting tabs/brackets...
