Well found the answer to this mythical axle lol...some guy on pirate4x4 was nice enough to put up link on all the info for those like me(crazy enough to use it lol)...
Dana 44 shafts, 30 spline:
Short side inner axle: 18 1/4" from center of joint to end
Long side inner axle: 35 1/2" from center of joint to end
Outer stub alxes converted to 1978
chevy 19 spline outers and internal chevy hub, bearings and spindle.
Need balljoints, same as any
Dana 44.
YellowIH
- Jul 07, 2008 · #3
Front Dana 44hd axle
Outer stub alxes converted to 1978 chevy 19 spline outers and internal chevy hub, bearings and spindle.
Need balljoints, same as any Dana 44.
Need a diff cover? Same as any other 44.
High steer arms....same as any Dana 44. I needed a small spacer.
You will need to cut and turn the front axle. Stock the IH truck axles had little if any caster built into them UNDER AN IH TRUCK.
On MY Scout II with extended shackles they had 1 to 2 degrees. I cut and turned them for more.
ALL CHEVY BRAKE PARTS USED ARE FOR 1978 CHEVY 3/4 TON 4X4. IF I SAY BRAKE PARTS, FRONT OR REAR, ITS FOR A 1978 CHEVY 3/4 TON 4X4.
