Oliver's
Drive Line & Gear
- Jul 16, 2005
We have a super clean 92 YJ 4.0 231J, 5sp, 34,*** OG Miles in the shop. Came in with what I would have called a drive-line angle issue from just having a 4.5" lift installed. Only thing that struck me kind of funny was this vibe really only came alive at high rpm 3rd gear thru 4th gear, after that you can't hear anything due to the wind noise.
Guy wanted to go from 3.55's to 4.56 gears, SYE and new cv rear shaft. Run of the mill, do it once a week.
Once all the work was done, now this vib comes in in 3rd gear like a light switch getting flipped on. Gear ratio difference, I get that, not the problem. First I assume it is the rear shaft and check the balance, it's good. Next I assume maybe the sye is bad, AA brand. I take it all back apart install another SYE and Build another shaft, exact same problem.
At the point I'm like WTF? I start ruling parts out. Ran it both on the road and on jack stands in 2wd and 4wd with both shafts installed, then No front drive shaft, then just the front shaft, no rear shaft installed, same exact thing.
My gut tells me it's in the t-case, but it's clean inside and all the bearings look good. The trans (ax15) shifts fine, the clutch seems to be fine. Tires are good and have been checked for balance. Checked the run out on the rear axle shafts, all good.
What else can I check?
Thoughts?
Thanks,
Dave
Thoughts?
Thanks,
Dave
