71chevytruckguy
- Nov 8, 2008
- Kernersville, nc
I'm leaning towards pinion bearings.
Let's work backwards.
The only time its gone is with no shafts. Since it follows both or either shafts that leads me to only 2 possible solutions
1) Both drive shafts are out of balance. Since it's you I am doubting this is the culprit just acknowledging it is feasible - We've checked the balance on both shafts, both balance near perfect, the rear has .001 run out. I'm confident it's not the shafts, since it does with just the rear installed and again with with just the front installed.
2) The issue is related to loading on the drivetrain. With no load no vibe. - Correct
So now let's dive into #2
A) Its present regardless of T-Case selection so lets eliminate that as the culprit. - Correct
B) Rebuilt Trans which eliminates internal trans issue, still leaves potential for some external alignment, mount hole wallow, bind issue however unlikely it may be still a possibility.. - Understood
C) Engine issue
If it were me and it couldnt be lived with (BTW have we established in this thread what kind of vibe we are talking about? Are we talking .."There is a slight vibration there can you feel it?" or are we talking "Holy Shit any worse and this qualifies as death wobble") but my first action would be to swap every mount in the vehicle. Both motor mounts, trans mount and t-case mount. The mounts primary purpose other than locating and maintaining location is to isolate rotational harmonics from the cabin. A failure in any of these could transmit those vibes even if they dont show any visible signs of wear.
The Vib is not death wobble intense, nor your "ok this is a jeep and somethings gonna vibrate" but enough that if not if not taken care of, will make what ever is making the vib cause a catastrophic failure imo. I should add to, the vib is making the bearings in both the t-case and rear extremely warm after only a few miles of driving.
If those are replaced and the vibe remains the only remaining culprit is the engine.
Id check the harmonic balancer and the crank shaft end play. And not visually, Id get caliper level run out measurements
Seems to me if the balancer was bad, you could make it vib with just revving the motor? Noteworthy of checking though.
EDIT - Wait just saw your response on the Clutch....before I did any of the above Id have the clutch and bearing replaced and the plate checked for run out/warpage on machine and re balanced. Visual isnt going to identify this level of vibe that I am assuming we are talking about.
Agreed.
Double Edit - Have alternate tires, wheels been used on any tests?
Have you mounted a gopro inner the rig during a road test?
So it does it in 3rd gear high range, and 5th gear low range. Are those both close to the same vehicle speed?
I haven't changed the wheels and tires out, but I have run the rear on jack stands with out the wheels/tires and it has the same vibs.
ain't slept all week anticipating the solution......![]()
This is a big indication that it's in the rear axle/wheels/tires because of the following reasons:
- Driving down the road with only the front shaft induces the vibes - This eliminates rear drive shaft
- Front drive shaft removed induces vibes - This eliminates front drive shaft
- 2 different transfer cases and 3 different SYE's were used - likelihood of both cases and all output shafts being bad is very small
- Running the rear while on jack stands induces vibes - this eliminates the front axle/wheels/tires entirely as they aren't spinning and also indicates that no load on the tires is needed.
- The vibration occurs whether in 2wd or 4lo - This eliminates the trans as the output of the trans is rotating at different speeds to obtain the same vibration around 35mph
If you read pack through all the way. He also did it on a lift with just the front shaft installed.
The customer has it back now, so unfortunately this one may go unsolved.
The jeep ended up back here again. The customer took it to another shop for another diagnosis. The shop said they found a spot on the ring gear that had zero back lash. I had the owner bring it back for me to check. After literally checking each tooth on the ring gear I only found a various of .001. I then took the ring off the true trac and ran it in the lathe. Zero run out on the flange and .005 on the journal. ECGS verified that wasn't enough for any concern. I reinstalled the ring gear 180 for what it was just in case, same pattern as before.
I moved on to the axle shafts to check for run out. The Pass side shaft had .005 at the bearing and at the spline, but had .025 in the middle. Thinking I was on to something I pulled the driver side (brand new) back out and checked it. To my surprise, it had almost the identical amount of run out.
I put both shafts back in and installed the c-clips, put the brake drums back on, and the wheels. I grab the tire once the lugs are back on and felt and odd lateral movement, not in and out c-clip related movement, (think old school front wheel bearing check). I grab it again to check myself and sure enough both sides do it, pass. side slightly worse. I put my mag base indicator on it, Pass side moves .017 and the Driver side .012. Is this normal? I honestly can't recall feeling that kind of movement on a rear axle shaft before.
If this is not normal, what could cause this? Bent housing? It has brand new wheel bearings, so I rule that out.
Thoughts?
