Oliver's
Drive Line & Gear
- Jul 16, 2005
Pull both shafts and run it in 3rd. I am not too very familiar without looking at a diagram but you said it vibes with front shaft only, rear shaft only, and on stands. Swapped case, no change. Definitely not in front/rear gears or the TC. My money is on the trans..... Before gear swap, it was high 3rd and 4th. After gear swap it was still 3rd. Worth a shot but it won't be loaded like with a shaft in, keep in mind... I have a good yj axle pair if you can get them down there, but I bet it's in the trans.. idk how but that's the only thing that hasn't been tested or changed.
The trans was pulled and gone through...
Yes sir, the trans has been completely gone through and rebuilt.
