ckruzer
Infidel
- Jul 2, 2015
- asheville nc
If you’re going fast with most of your shaft out…..
This is the correct wand method harry uses to gain access to someone's chamber of secrets
Just the input, not the output.But engine speed has zero effect. So that rules out the transmission as well.
The one that's supported by the transfer case input? I don't see any way for it to vibrate.Just the input, not the output.
I can always count on you, sweetieBuy the 35 stickies @Van-go is selling, send that rock missile up some trails, let the new vibrations hide the old vibrations.
I’m here for more bad advice when you need it
She signs my paychecks. She can buy her own DenaliDoll that ZJ up all nice and shiny and pass it on as you can always do then buy her a Denali Yukon and let her enjoy life in luxury! It's a sweet ride and it ain't gonna vibrate!...unless you push the button for it to.
Convince Lisa to do it to HER ZJ and I'll buy you a White Claw in a a yet to be determined wheeling location
Wut?Haha on a serious note.
I’m assuming you’re measuring the pinion angle static sitting in the shop floor or parking lot. Is there any chance that when the driveline loads up, the rear suspension squats a little or even while it’s going down the road causing that angle to change for the worst? I know the pinion angle doesn’t change as much in a coil spring suspension like it can with leafs, but we are running out of things to check and these are random things that pop into my head and whilst evacuating the AM grumper.
This is still where my money is. Trans output shaft/bearingJust the input, not the output.
Explain how that can cause it. Really not being argumentative, but I don't see how it's possible when the trans output is fully supported in the extension housing as well as the t case input.This is still where my money is. Trans output shaft/bearing
Just front, just rear, multiple combos of various known good shafts and no discernable change.Have you tried removing both driveshafts, putting it in gear and “running it up to speed” while sitting still?
Driving with just rear shaft? Driving with just front?
I’m still not convinced it’s not a driveshaft issue.
Hell, take both shafts out and coast down a long hill with no driveshafts till you hit 55-60 and see if it does it.
Why bother with good bearings in a rearend setup? They are fully supported in the housing.Explain how that can cause it. Really not being argumentative, but I don't see how it's possible when the trans output is fully supported in the extension housing as well as the t case input.
Reading through this thread, everything in my head points to T-case bearings on the output side. You said it was originally vibing around 70. Then switched from 3.73 to 4.56, and the vibes dropped down to the 54-60mph range. 3.73/4.56*70=57mph, dead in the center of the 54-60mph you stated earlier, and the 55-58mph that has been stated more recently. So its at a particular driveshaft rpm zone. That pretty much eliminated anything from the carrier downstream. And this mostly rules out engine and transmission, unless the harmonic just doesn't present itself in the first few gears. One way to eliminate those for sure is pull the front driveshaft, put it in 4low, and drive at about 20-22mph, in OD gear, which should be the same RPM (assuming 2.72 t-case gears). If the vibe is there in 4low at same rpm in top gear, then its transmission output or t-case input. Honestly, could be something as simple as the front bearing on the t-case rear output shaft being worn and allowing some harmonic oscillations, especially since that end is pretty much only supported by another bearing.
That's the plan for tomorrow am.If you remove the rear drive shaft and repeat the test you could likely eliminate Matt’s theory. Or, as he suggested, retest in low range just for process of elimination
Axle shaft bent? Or housing bent?Put it in stands after work and had my wife run it to 55-65 mph. It does it clear as day, you can hear it and feel it. If you place your hand on the rear diff housing, you can feel the resonance, you also feel it on both uppers as well as the track bar.
Remember the Jeep is stationary, but you put your hand on these parts and it's like being in a washboard road. Crazy
While it was vibing, I side loaded the bushings on each part w/o any change in pitch or feel. You cannot feel it in the hitch, exhaust, gas tank skid, etc. I'm unsure if this is a cause or effect.
Laying under it, when you hit 55 and it starts vibing, you can see the nose of the housing start to go up and down a bit. As you would expect, the axle end of the driveshaft follows the pinion and moves a bit too.
I found a leaking axle seal, so I pulled the locker to access the c clips. Tomorrow, I'll pull the carrier to triple check pinion bearings and such.
Oh, I also removed the crossmember and set the case on a fixed pipe stand in an effort to rule out the tranny mount. No change at all.
Essentially, nothing I pried, moved or touched changed anything. But at least I can 100% replicate it in stands and can feel it.
Thoughts?
Straight edge on housing doesn't indicate it. Watching the caliper mounts as the wheels turn at speed and there's no side to side movement seenAxle shaft bent? Or housing bent?
