UncleWillie
Rarely serious.
- Dec 29, 2010
- Vale
To whomever engineered the engine in a Honda Passport. I hate you with the searing hot heat of a million suns going supernova in a cup of McDonald's coffee. Who in their right mind puts the thermostat UNDER the intake manifold.
I can hear the engineering meeting now.
Idiot #1: You know what, this thing is entirely too easy to work on.
Idiot #2: You're right. We should put the thermostat under the intake.
I1: Yes, and let's put it under a steel cooling line that makes it almost impossible to remove one of the bolts, and then very hard to remove the water inlet housing.
Supervisory Idiot: You guys are thinking small. See this tiny emissions solenoid, well, let's put it on a huge metal bracket.
I2: How will that make things harder?
SI: You don't follow me. We are going to put it to where you cannot remove the upper intake with it in place, then put a bolt behind it almost touching the firewall where you have to be Houdini to get to it.
I1: Ohhh, and let's use allen head bolts so that there is no possible way to get an allen wrench back there without taking a grinder to it unless you buy a $300 tool.
SI. I like where your head is at, but let's route hardlines over it, firmly attached to the firewall, so that you cannot turn the wrench.
I2: And let's put all kinds of stuff below it so when you drop your ground down allen wrench it doesn't fall through to the ground, and the mechanic has to grind down multiples to get it off.
I1. Oh, and lets torque it to 987654356789 pounds so it is impossible to turn.
SI: Yep, boys, we got a winner.
