BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
Has anyone ever used the propane mosquito capturing machines? I need to figure out something to help control the mosquitoes in my back yard.
x2The bastards will pick you up and carry you off at my house this year.
Off deep woods dry, problem solved. Helps if you don't have standing water everywhere too.
Sent from my iPhone using Tapatalk 2
Mosquito Authority. Note the period.
Bifenthrin is a insecticide pest control companies use to control pests including termites
It comes in a Granular form, that is easy to spread with your average cheap lawn spreader, application rate is 2.5lbs/1000 sqft, and it is available in 25 and 50lb bags, normal cost should be around $1.25 per lb
now here's the best part, one application lasts about 30 days, and it will control mosquitoes, fleas, ticks, worms, fire ants, large and small ants of any kind, bees that nest in the ground
I had my exterminator service (Bulwark) add their mosquito treatment to these summer months. They come by every 3 weeks and cover every inch of my property. For the first time ever, I can hang out in my wooded backyard without being coated in DEET and not get lit up by every skeeter in the county. It's the same service as Mosquito Authority. I can't recommend a service like this more.
How much $? I've got about an acre that needs attention.it can be bought at your local Professional turf and ornamental supply company, maybe your local feed and seed company, it also comes in liquid form that can be sprayed
or you can buy it from me, and I will ship it directly to your door step
90% of mosquitoes come from Larvae hatched out of the ground, whether it be hosted by grass, mulch, or wooded lots
