Futbalfantic
- Aug 5, 2006
- Charlotte
Unless they beat the cycle of the light. Now they at least save a minute. And if your anything like me. That minute counts for a lot.
Not illegal to drive with your tailgate down, though. And it isn't our fault that their cameras suck and can't take good camera angles.![]()
Sucks my tailgate is broken and won't latch, right?To expound on this a bit.
Correct, definitely not illegal to drive with your tailgate down. However, if you are taking a toll road every morning and afternoon for work and leave your tailgate down, its pretty obvious what you are doing. Those pictures that don't have tags are labeled "UO"(unidentified object) and then sent to manual review. Pretty easy to establish a pattern from there.
All that being said, carry a 2x4 in the bed with the tailgate down
The camera's are actually pretty good, capable of catching tags up to 200+mph even on a bike. They are just mounted at high angles.
Those 2 more times happened 3 times each in May.Only 2 more times to go then.
Is there any kind of radar or similar built in to the camera stations? Has anyone verified the 200+ mph claim?To expound on this a bit.
I think the highest number I've seen was 163ish from SHP responding to a felony wrong way driver chase.
That's gettin it!I think the highest number I've seen was 163ish from SHP responding to a felony wrong way driver chase.
Narc!Yes/No. The cameras were built and tested out in Arizona at a track at near those speeds. During ITS configuration before the expressway was opened we tested the cameras at speed. The ITS company had a few mustangs/camaros plus a Hayabusa that made a few runs at 150+.
Yes, I have access to all speed data from the gantries. That info does NOT get sent to SHP/LEO but can be sent once I'm subpoenaed. But the speeds are recorded/captured as part of the data.
The max capture speed just comes down to camera frame rate and time in the field of view. If you can make it through the field of view and time it so you’re in between shutter clicks, then you’ll get away scot-free. Camera tech is most certainly better now, but when I was doin it, we used 30 fps cameras and the fov varied but let’s call it 50ft.Is there any kind of radar or similar built in to the camera stations? Has anyone verified the 200+ mph claim?
Serious question here. What happens after they manually review and establish a pattern. If nothing illegal is done, do they post a cop and pull someone over for driving completely legal. Just curious, I don’t drive the toll roads.To expound on this a bit.
What is the farm equipment concern? People using improperly tagged vehicles on the road?These days we worry more about farm equipment, wrong way drivers, etc then a tailgate being down.
Or if they wouldn’t have stuck the road through the rural area in the first place the farmers would left to do their jobs in peace….. IJS….@RatLabGuy the roadway is in a fairly rural area. So during spring/fall we get combines, sprayers, tractors etc using the roadway to get to fields/other properties instead of loading them on a low-boy. It's a controlled access facility so they aren't allowed per NC law. Plus we have to worry about tight ROW/shoulders/guardrail and overhead gantries with oversized equipment running up and down the road. Those overhead gantries contain a lot of high $$$ equipment and the concern of damage is real.
Its never fun when you are running 70+mph and come up on a combine running 25mph and taking up the entire right shoulder and lane. SHP tries to keep them off but with only two officers running 20 miles of roadway with no median turnaround its tough to catch them before they get off the facility.
Since we're on the topic...any idea what the tolerable speed threshold is?with only two officers running 20 miles of roadway with no median turnaround
