Chris_Keziah
Joe Dirt @ Rev Limit Fab
- Dec 1, 2010
- Winston-Salem
F250 shock towers and be done. You just gonna try standard cross over steering first?
Yes, that’s the plan. I may need to notch the frame up and get a flat pitman arm. We will see.F250 shock towers and be done. You just gonna try standard cross over steering first?
It cleared at lock to the driver side, but not to passenger with standard TRE’sYou’ll need two small bends to clear the diff cover if you aren’t moving the tie rod location from the original knuckle location. My 05 with a recessed cover from ruffstuff and Barnes offset heims still hit at full lock.
We’ll see how the offsets do.
Already ordered. Thanks thoughIve got a set of offset tre if you wanna try before ordering a set.
I’m waiting on this guy to finish his taco so we can work on getting the puzzle figured outI'm still waiting to see the purple YJ build![]()
Pitman arm finally showed up. Should be the last piece I needed for the steering. Hopefully I’ll have it all mocked up by this weekend.
It’s from sky. It’s beefy and I like how it’s machined so I don’t have to cut up into the frame as much for the nut.Who makes that. It’s saaaawwwweeeeeettttttt
