Van-go
Not an old man
- Dec 11, 2014
- Greensboro
Picked up a pop up to mount to my gooseneck this morning. @upnover cam by and got some of my junk. Good to see you Chip.
Been working on my drag link this afternoon. Had to do some odd bends and notch it out for my idler pulley, but got it to clear everything.
I may.You gonna weld the rest of that flat bar on the inside of the frame?
Yeah. I’ll probably knock it out tomorrow. Just left it open to get the inside welded up.Looks good. Any plans to plate in the opening?
Well done! Nice job on matching the curves there. Coming along great.
Thanks. Slow, but coming along.
How much frame flex is too much? It still flexes a little. Gonna add some more plates on that side but it still definitely flexes some even with two 3/8x1-1/4 plates on the inside and 3/16 plates on the outside.
Gonna add this too to help. I may end up plating the passenger side outside frame rail.
If I put jack stands under the front crossmember and lower it down onto the stands the front flexes up.Flexes which way?
Jack is under t case crossmember
Yeah I just can’t go up higher on the outside cause of the steering box. I can go higher on the inside of the frame where that cardboard is.Need to add vertical height back to the frame, that cardboard piece should help some.
You could also stiffen with tube, by building a grill hoop and triangulating it back to the frame/firewall/A-pillar.
These newer trucks usually get the whole front frame section plated up on both driver and passenger to prevent flex, whether linked or on leafs as far as I have seen. The front frames are quite thin on them. I would do the whole thing on both sides personally.Thanks. Slow, but coming along.
That’s what I’m leaning towards. Why not right? lolThese newer trucks usually get the whole front frame section plated up on both driver and passenger to prevent flex, whether linked or on leafs as far as I have seen. The front frames are quite thin on them. I would do the whole thing on both sides personally.
I would say so lol. It’s why the Toyota frame plate aftermarket has so many options. Wish I would have sold you the set I had with the truck but my buddy needed them. HahaThat’s what I’m leaning towards. Why not right? lol
@Chris_Keziah what if I added a taller plate rather than just where I had the cardboard cut out?
I have room on that side behind the box.
How thick of plate should I use? 3/16 is what I‘ve been using but if I go right behind the current plate on top of the frame I could use a thicker one.
View attachment 304844 View attachment 304845 View attachment 304846
Can’t do full hydro... airbag clocking ring in column will break and I’ll loose all controls on the column. Cruise, horn, blinker, etc.If you just moved that steering box to the work bench you'd have plenty of room for an orbital. I'd try to build a box spine on top as tall and wide within reason. Really hard to tell but doesn't look like a terrible amount of room.
What about a tube underneath it?You could also stiffen with tube, by building a grill hoop and triangulating it back to the frame/firewall/A-pillar.
I was thinking something like this with a heavy wall DOM. Only thing is keeping it tight enough to frame may hamper getting the pitman arm off without removing the steering box??
So I looked a little harder and it’s actually not flexing where the notch is. It right behind the plates where the frame is bare. So I guess I’ll be plating the rest of the frame like @Wesling Ducos was saying. And still adding more to the notched section.I was thinking something like this with a heavy wall DOM. Only thing is keeping it tight enough to frame may hamper getting the pitman arm off without removing the steering box??
