Van-go
Not an old man
- Dec 11, 2014
- Greensboro
I see. I should have made it like the one in my YJ. It was all .120 wall so I added more braces. The lower on this is .188 wall. I didn’t think it was an issue. Should I for sure go back and add some more triangles?Enjoying the build, makes me miss the simplicity of leaves.
I have a suggestion on your traction bar. I've built a few and had a couple failures years back.
You've created a bending point at the bottom of your small brace. The rotation in green will try to bend the bar at the red area. I would suggest triangulating on a truss style fashion (blue) to spread the load.
Keep the progress coming.![]()
I bet it would make getting steering packaged a bitch if he moved the crossmember up.
@Van-go I'm not sure what tire size you plan to run but I would try and move the axle far enough forward to leave a 1-2" of clearance at the firewall.
time to get some work done. I don’t mind it. It’s a new build and one I’ve never seen anyone else do. Didn’t really have anything to base it on being so new. Most people 3 link things this new. I decided to go back 30 years in suspension technologyI hate to see so much stuff break on you. Great build by the way.
Yeah I pulled it out of the garage and i didn’t like it.Much better, the first one was way to overlandy.
