Operation 'Basket Case MJ'
Likely the chain is the only thing not salvageable in that unit, 3 years with no oil and a little humidity could do that, but the cast/ machined parts should clean up. Always best to get a new chain when rebuilding as they can stretch to the point where they grind on the case with larger tires and off-road use
I did take it all apart and treated the cast/ machined parts for a couple weeks but most of it was way gone past saving. The case was stored indoors the whole time I had it before I cracked it open. This was water 100%.
Guess it would depend on the terms as to how it was sold. But at this point it would seem to be a non starter after sitting “in your possession” for that long (not saying it’s your fault at all! ) just saying…… YMMV
Yeah, I'm just gonna let it go. It was represented as a working pull with fluid in it...
This was worth the wait. I was thinking that massaging the drag link's bends to gain steering clearance on the passenger side would be a solution. That works, but having to replicate that on a wear item on a big lift when a replacement is needed wasn't an attractive option, long term. This build has required a few things one would call a 'big ticket item' but aside from new tail lights from Key Parts (coming early November) and at some point a Dana 489 from ECGS, this is probably the last.
OMG this Trail Forged setup is BEEF. Steering clearance issue is solved. Their instruction setup pics have the steering damper on the tie rod with a factory track bar (?!). My TB interferes so I have it on the drag link instead. Mocked up with lengths set within a degree or two on the toe, nothing tightened up yet. I ordered mine bare steel for DE1634 coat instead of their powder coat (black not availalble). Next is to pull and paint and reinstall and check toe again and adjust as needed to get close enough to drive it to the alignment shop. Did some computer work on a friend of a friend's Hunter alignment machine so I'm invited for an "as much time as you need" alignment. :)
Long time, no update. I'm stuck waiting for a different drag link from Trail Forged (long story, we'll see how it ends - Update 11-14-25: it'll be here probably tomorrow, 11-15-25).
So in the meantime, I'm trying to pick off anything else I can ahead of the maiden voyage. I picked up one of the last 10 pairs of black-trimmed Key Parts tail lights. Now out of stock, I have my doubts they'll do another run. I meticulously cleaned out the tail light pockets, re-coated the insides and hung the new lights:
I went to the trouble of cleaning out, re-greasing and sealing the original wiper motor maybe 2 years ago. I jumpered it in high and low positions directly with a battery, and it's slow and noisy. Technically it works, but no sense using it and then replacing it soon out of frustration. I got the harness from a 2002 WJ- the colors are slightly different from some of the XJ examples posted elsewhere here but no big deal. The WAI WPM447 has the connector and is $4 cheaper than the WPM438 with no connector. So I built an adapter to keep the harness side uncut and connect to the newer motor.
It's about a foot long, more than needed, but again, no big deal hiding inside the wiper cowl.
Finished up the wipers on Saturday. The harness adapter works with no issues. I was wondering what I was going to do about not having the rubber jacket around the motor and I had a thought pretty far outside the box. That's a microwaveable meal tray trimmed for flexibility and fitment is more than acceptable lol. I spent parts of 2 days getting all the scale and peeling clear coat off the cowl cover with a .002" feeler gauge and soft brass brush. Then wet sanded the lines between base and old clear. Next, some dish soap and 1200 grit on the areas of base that had been exposed to remove oxidation. I also touched up a few spots with a very small brush - sprayed Rustoleum Colonial Red in the cap and dipped the brush in it. Finally, I cleared the whole thing with Upol/ Raptor diamond coat 1k. I'm impressed with it, dries very hard and very fast and has very decent UV protection. Maybe one day I'll fork out 8-10k for a real paint job but in the meantime I'm just trying to keep it red and protected from peel and rust.
New later arms...
So I basically took from Thanksgiving through New Year's off from my own projects. I did do brakes and motor mounts and tires/ alignment on my wife's XC70 but mostly left my tools in the box for a while. Basically kept the MJ battery charged and looked at it now and then. Now getting back to things to get her rolling under her own power.
Covers for the milspec terminals (Fastronix, made in USA, $13.87 shipped):
Homebrew toe setup - flip some spare 1/2" - 20 lug nuts around to hold the toe measurement bars with the rotors snug. Angle aluminum tends to be more true than steel angle iron and it's lighter. Frequently check they're level when making adjustments and re-measuring. Shoot for 1/16" less up front for about .5* toe-in. I used a laser angle finder and started with the beam at centerline of the rear tires and moved each side outward equally until I got the measurement I wanted. Then measured center to center on the knuckles and transferred that to the tie rod. Close enough to get it to my buddy's alignment shop.
I just drove it for the first time ever, around my neighborhood. Running and driving is silky smooth. It's still a ways away from finished. Bugs to work out - the temp and oil pressure gauges are pegged. Oil pressure gauge sweeps at key on, temp does not, both gauges worked fine some months back when I was tuning and making engine running adjustments. No big. Right fender liner still needs to go in, lots of clear coat correction and repair, little things. No tool exists to measure the width of my smile today...
It's been a while, 2 jobs and life stuff taking most of my time. A couple weeks ago, I tackled the pulsing lights at idle issue with the Durango alternator/ external regulator issue. This past weekend, I got the fire extinguisher mounted under the passenger seat, using existing holes in the front bracket. I'm satisfied with it, easy to remove for vacuuming and reminds you to check the date when you do... Made by Shield, right here in Kings Mountain, NC.
The bed hasn't been empty since I started pulling it apart back in April of 2022. Feels good. There are 3 small dents in the rear wheelhousings I'm going to work out soon. I have a lot of odds and ends for sale locally on CL. I'll post in our classifieds as well. Looking to offload most of it free or cheap(er) than on CL, somebody can use it hopefully.
It now has a temporary tag and is legal to operate on NC roads. I want to iron out the clutch master to 100% confidence vs warm restarts/ difficulty getting into 1st and reverse, and I need to tweak the toe adjustment. I found my custom fasteners for the passenger fender liner right after I ordered more. It hasn't been over 40MPH yet and lots of stuff needs to be tested/ verified at higher speeds:
- Cruise control testing/ adjustment
- Death wobble testing
- Road feel with fairly little caster/ higher rear end than I like
- headlight & fog light aiming/ adjustment
- Overall engine performance/ driveability under differing loads & conditions
Oh, and my personalized plate will read: 87-99 MJ
Here's the Durango alternator swap documentation for anybody who wants to do it in an XJ or MJ.
The physical compatibility and arrangements for this has been well covered but I wanted mostly to cover the electrical part of the swap. And if you do it, you may have all lights pulsing at idle. I did, and here's how I fixed it, thanks to one of (inventor of the REM II) Nick's friends...
For stock alternator location:
  1. There are plenty of 5.9L Durango alternator swap guides out there, mostly for 91 and up. Those don't require a bracketry swap, as the alternator case mounting holes are the same, just a larger case. Those require some shaving and cutting to accommodate the larger case, and that's well covered on the internet.
  2. For 87-90 Renix Jeeps equipped with a CS-130 case alternator, the brackets are entirely incompatible. This will require swapping to the 91-98 alternator brackets and likely a belt change.
For top mount, non-A/C equipped jeeps:
  1. 87-90 will require swapping to a later 91-98 A/C compressor mounting bracket for most top mount conversions. No one I've seen makes anything to mount the later alternators on a Renix A/C compressor bracket.
  2. 91-92 MJ & 91-98 XJ already have the later A/C bracket, ready to go. I got a USA-made top mount alternator adapter kit from SpeedShop505, but they're not making this as of March 2026. Plenty of other copies out there. Belt change is required.
Larger Images of Electrical Diagrams here: ---> Durango Alt Wiring
Electrical:
Going from this (p.24 1988 Comanche Electrical Manual):
To this:
Complete regulator and relay harness:
Harness Explanation:
All lights pulsing at idle - common issue when doing this swap! The yellow field wire on the original Renix alternator connector is usually the indicated switched 12V source. However, it comes all the way from the ignition switch, through Splice D, through bulkhead C100, through Splice R if you have A/C, through Splice E, through connector C335, and finally to C205 at the alternator. This is a run of about 10-11 feet! Plenty of noise and voltage drop opportunities. Nick R (NickInTimeFilms) and a buddy of his did this swap in a YouTube video:
The 89 XJ in the video already has the 91-98 A/C compressor bracket due to a previous HO-era A/C swap, and they're ditching that in the video, but that's not the point. The wiring is (11:24 - 18:12). In the comments someone asked if the lights pulsed at idle, and the owner, tylermus, replied that he'd added a relay next to the battery to eliminate the issue. So that's why I did this, and it worked great.
There also needs to be a ground wire from the regulator body to body ground. I added a large ground on the passenger side to mirror the one on the driver's side fender well (G106), so I tied into that. The 20A fuse between the relay and battery is optional, I did without.
I unplugged C335 and tucked away the side for the alternator harness. Rather than cut anything, I headed to the local boneyard looking for 88-94 Chevy TBI V8 trucks. It's the brown wire connector you unplug when setting the distributor base timing on those trucks. On the firewall under the PDC cover if the truck still has it. I got the Field wire 1&2 connector from a random Jeep/ Chrysler vehicle a while back, don't recall exactly which (easy to find).
External Regulator kit is from Alternator Man / alternatorparts.com, kit ERCK. Setup and explanation video from the Alternator Man himself here:
One more note: if you have a "Standard"/ dummy instrument cluster...
NOTE: I'm 90+% certain this is correct for trucks with the "Standard"/ indicator light cluster.
whats the plan for bed? I have extra plastic bed liner insert if you want to go that direction
Wow, I didn't even know such a thing existed anymore. I had strongly considered having it spray lined. I'm paranoid about putting in anything that hides or traps moisture and dirt, but it's super tempting because it guards against scratches and dents. PM me with what you had in mind on price. A lot to think about now...
FREE
Ok, wow, yeah! That's very generous! I'll have to haul it back here on a Harbor Freight trailer behind my Accord. The MJ hasn't been shaken down properly yet and I'd hate to get myself stuck in Raleigh if something dumb failed...
Reality check - I have a 6' box. Is for a 6' or 7'?
ill verify when home tonight but pretty sure it is the size you need
6' bed
Minor update - I swapped injectors today to some Bosch EV6 I haven't seen anyone try yet. These are spec'd as:
0280155702 | EV6 | Long | Jetronic |4-hole | 200cc/min | 16 Ohm (very dark grey)
I checked the resistance and found them all to be 16.8 - 17.2 Ohms. Not a bad thing necessarily, was shooting for 16 - 16.3. I ran them at 31psi confirmed fuel pressure. The STFTs at idle show just a touch fat at 110-114. I'll need to drive it a while to let the LTFTs set themselves but it looks like a solid winner for my particular rig. It's like a tiny bit smaller version of the 746. I'd like to see real world Ohms resistance on a set of 0280155700. If they're 'real-world' above 15.2 Ohm, I'd pronounce the 'Volvo 700' the most ideal injector possible for any Renix-controlled Jeep, bar none. I say this because my motor is HO, 7120 head, bored TB, 2.5" exhaust and it still doesn't seem to really want more fuel than a stock Renix, except possibly above 3500RPM, where the better head flow makes a bigger difference. Renix and 91-95 HO cams are identical.
What I took out were the ones that were in the motor from the 93 YJ, old Bosch-for-Ford 20#:
0280150943 | EV1 | Long | 4-hole | Jetronic | 210cc/min | 14.3 Ohm
I had to turn those down to 24psi fuel pressure and it still smelled rich, and the oil was getting fuel-contaminated.
I was just changing out the transfer case front output yoke seal (thought I'd done it but nope) and noticed something just peeking out at the trans inspection cover/ spacer.
If you know what this is, you know how I'm feeling right now. I've had it with internal slave. Advance Adapters conversion kit ordered today.
After swapping the clutch master with a LuK LM206 shifting into 1st and reverse when warm was a lot better, briefly. Slightly cockeyed slave engagement took that away. At least I know what happened...
The level of frustration with not being able to just get out and drive is getting to me. Spent a decent chunk of yesterday doing a blower motor in a Volvo XC70 (ask me how much fun that is). Today was my day to replace the transfer case seal and take it out for some more miles in nice weather. :mad:
You will be happy with external slave for sure. I would suggest you bleed it before putting it on, some of the pre bled units are not so, likely due to being inverted at some point during shipping. I take the cap off and with the slave dangling under the car, and cycle the slave a few times by pressing against something like the Bellhousing to chase any air or, then use the plastic straps to hold the slave pushed in for install
Yep, good call. It'll be 110% less worry with external. I did a complete clutch & hydraulics replacement on a 2000 Dakota 4.7/NV3500 for an injured neighbor about a month ago, just like you said. Easy peasy. Almost the exact same job, really.
