Toyota Dad
- Jul 15, 2006
- High Point NC
Toyota
Very Nice job with the Truck
Yep, newer GM HDs (and SOME later model 1/2 ton 2wds with torsion bar instead of coilspring, plus the 07+ coilover 2wds) are the same way. 2wd/4wd share the same suspension, steering, etc. Just need to add the transfer case, diff, axles, swap out the 2wd hubs for 4wd, add the crossmember with mounts for the front diff (slight fab work, but not much, cut it off a wrecked 4wd truck and weld it right in on a 2wd), and voila 4wd. I actually cheaped out on on my 2wd Duramax when a hub went bad, 2wd hubs were $250, 4wd hubs were $100, I used a 4wd hub, and disassembled the stub shaft of an old CV axle, stuck it through the 4wd hub, and instant 2wd hub for 1/2 the price.Wow,cool. Are the frames etc the same? Surely it''s not just that easy ;-)
You gonna go duals or just 4.7?
wow this is nice! wanna trade for a zj????? haha
i would be too!Thanks! I'm good, I could never part with this hunk of junk... i'm attached
Josh and them do great work you wont be dissapointed! Are they going to be doin the SAS to?Dropping the truck off at Universal Automotive tonight and the 4.7 case is going in tomorrow!
And so it begins
