Project dirt dobber
So I found out why my pass rear wasn't pulling. I pulled my diff and found this
So I welded it up right and threw it back in, should be good to go from here.
I worked on my full hydro and got a lot done, orbital was mounted and welded my link to the steering shaft, mounted my ram, worked out well for a big cylinder, I'm happy with it and he price of it, all I need now is the pump bracket and I should be good to go I should have the belt tomorrow as well,
Yep just got off the slopes rode by crozet on the way wish they still haf open rides
Sent from my SCH-I535 using Tapatalk
Me and trey went 1 time it was great I broke all my hub studs 30 min after we got there but its pretty tecnical like one giant rock garden but over all pretty small
Saved some pics from online, from karatejosh or x-jeeper, looked cool
ai1052.photobucket.com_albums_s455_orv_design_fab_1507068_10155b85050526c882ccdc9db14907c550e8.jpg
ai1052.photobucket.com_albums_s455_orv_design_fab_1526417_1015f524d23b12393474cc77624ef5096b3c.jpg
Thanks bud! Sorry I haven't called you back. You have to go wheeling with us,
I wish I could say I cut it out with the plasma table...but I didn't
I broke something in my transfercases... We shall find out soon. The flats is coming up in two qeeks
So I fired up the heaters in the shop and pulled my cases out. The rear is trashes. My rear input is a 23 spline marlin so I'm excited about that. Swapped the input shaft out in my new case. I have to replace all my harware to bolt the crossmember back under the truck, but shouldn't be bad. turned out nice! All I have left to so I bolt up my tc pump fory full hydro, and check all my fluids. And go over the truck with a wrench and I'm set. Next Fri looks like I'm rolling out.
While josh had jack stands under the front end, I found a loose wheel bearing so I tightened that this evening after work. Should finish up wed. And load it and tighten all bolts thurs evening. And roll out Fri am :) its gonna be a good weekend.
