ghost
- May 25, 2006
- Hartsville/Camden,SC
If you don't want me there you better not give me your address or time that said party is going on.....
Wow there is no room on the driver side for link mounts.......
It's a 14 bolt spider gear. Make sure to file the sharp points first. I tigged a washer on one side to stick the threaded shifter through and then tightened a nut down.
As far as a cell goes, the biggest question is if I rather carry 15 gallons or 19. Having a backseat is not of concern.
Rhodes Race Cars makes cells identical to RCI but slightly cheaper and rumor has it, a little thicker. They advertise .100" thickness. I had a bottom sump RRC 20 gallon on Savage Amusement and had no failures.
So it's down to the 2161 (15G) or the 2191 (19G).
Tried to help you out, looked at belt on 6.0 TJ , but numbers not readable. Sorry. YJ project looking good!I can't remember off the top of my head which belt I used on Savage Amusement (6.0 TJ), but it was a Goodyear Gatorback. I'll do what I did last time and size it up with the handy length chart.
https://m.summitracing.com/search/product-line/goodyear-gatorback-poly-v-serpentine-belts
Mine is complete with all truck/suv accessories in stock location and minus the AC compressor. Very common size. Once I figure out what length I need, I'll post a part#.
I've done 8 so far with good results. Page 3 or 4 has some details on it with a hydraulic parts list. If you have one that needs it, send it my way.
