2 steps forward...100 steps back. After talking a bit with a friend who has a lot more body experience than me, I've decided to pull out the sheetmetal I had previously installed(rear fenders). Two reasons, 1. I really didn't like the way everything came together, too many little pieces welded together(all based on my inexperience with body work) and 2. he informed me that those pieces would pull apart in no time because I didn't incorporate a seamed joint in them. So I got to learn a valuable lesson
Sure looks different without the body on it. Also, I'm in need of body mounts as the previous ones were 2x4s.
Tub is pulled off and you can see where I removed the DS fender. The PS side will be removed and replaced. I went and built a metal brake so I can make accurate and clean bends in the sheet metal.
Since I'm incorporating a seam into all of the joints, I needed to find a way to bend the panels with the seam built in. Quick stop by HF and I got a metal stretcher/shrinker and built a small table for them. First time using any tool like this and it was a lot easier than I expected it to be.
I cut out the rest of the rotted rear floor and built a subframe. I still need to pick up a piece of 16ga steel to build the rear floor but have enough metal to finish out the fenders.
I have some very rough templates mocked up for the trans tunnel and I'm thinking I will use weld nuts to attach the trans tunnel to the subframe so it can be removable for trans/transfer case maintenance and adjusting the clutch linkage.
The interior will be herculined(or better equivalent) and the bottom will be POR15'd(or better?). I picked up some Corbeau SS seats from
@Oliver's as well as two shiny new driveshafts a while ago. Driveshafts are in and the seats are still in the box. Once the tub is finalized I'll get it back on the body and start wiring/plumbing the engine. Then its on to steering, brakes and I can finally move it. Final work will be paint/cage work.
