Jeff B
Thanos was right
- Dec 23, 2006
- Lincolnton N.C.
30 amp fuse and a relay
no brake booster?
If you want to go powered and non-hydro, you can use one like this: 7" Dual Diaphragm Zinc Street Rod Power Brake Booster Universal Ford Chevy NEW | eBay
I like the look of that but I'm worried about hood clearance. I found the same one on speedway and it shows the dimensions on it and it looks like it could "work". I need to make some accurate measurements tomorrow and check. The only concern I would have would be all that weight hanging out there in the engine bay and being attached to the paperthin firewall. I could always plate the backside of it for added strength.
I also noticed what looks like bolts in your high steer arms? I suggest you remove those and install studs and the tapered lugs nuts.
Now that the farm table is "finished", I can start back on the Willys. Picked up an 83 CJ steering column off the board from here and got it installed.
However, this leads to this issue.
As you can see the end of the steering shaft is about 1" away from the exhaust. I think I'm going to have to go to a header style that dumps in the middle on the driver side to get around this. It's a small update but progress is being made...
With the header style, you will still need an extra knuckle and a bearing to get to the steering box. Should clear by about 1/2" IIRC
Great work on the project.
The steering wheel is unbelievable.
One item of concern. On brake lines to the MC, they go directly to it.
Often manufacturers and others make the brake line into a coil pattern (like a pig tail) to the prevent flexing of the fire wall and other moments from stressing the brake lines and causing a failure.
An example is seen below:
Just my $0.015 worth.
These headers look like they would allow clearance.
https://www.summitracing.com/parts/snh-cv95-p/overview/make/chevrolet
but then im worried about motor mount clearances. Looking on summits website/reviews I saw that a guy was having issues with the passenger side clearing driveshaft. I might have to run two separate types of headers. I don't think this would cause issue with anything or am I wrong?
Flaming River, Borgeson and other steering u joints are available at Summit and AmazonSo I went to the junkyard and pulled an OEM manifold from an Astro, no dice. Did some more thinking and figuring and decided to shorten the steering column. Fortunately, the steering column had a slip joint in it with plenty of room. I shortened the column by around 4" and now the steering shaft gear is just outside the firewall with about 6" of clearance to the headers. Now I just need to find a u-joint that fits the steering column as the one that came with it is pretty trashed. I'm pretty sure its a 36 spline 13/16" shaft. Can anyone confirm? out of an 83 CJ.
