jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
49 degrees near Charlotte this morning. Felt good to go outside and not start sweating.
When I was in auto classes at fayetteville tech cc, a classmate hydrolocked at 4.0 92 yj. It blew a 3" hole through the block below the coolant jacket but above the oil pan rail, and a crack ran from the 3" hole to the oil pan rail. We got the instructor to weld a 1/4" plate over the hole on the inside, and he welded the crack too after v notching it. We then filled the hole from the internal plate to the outside of the block with jb weld an 1/8" a day til it was flush. The last day the instructor took a shop rag and blotted the jb weld when it got tacky so it had a cast iron texture.Quick steel on a cracked cast iron block after trying to fcaw the cracks with little successk chasing tiny pin holes, grind weld, make more tiny pin holes, lather rinse repeat).. I am certain quick steel (epoxy compound) is made of hopes and dreams. I hope and dream it will work. If not, I guess I'll try to find someone with torches or Tig to braze it for me. Cracked 4.0 next to the exhaust manifold and water pump about 2" long
Your fingers have the second most dense array of pain receptors in your whole body, with as much brain-space dedicated to your pointer as to your entire back.It doesn't matter how big and bad, or macho you are. You get a tiny metal sliver in your hand or finger and that little booger will let you know who's your daddy until you get that thing out.
I used to think it was my pecker, but as I get older, I realize that I just blocked out feelings from all the other body parts and focused on my pecker. Now all the other things hurt and my pecker barely feels anything.Your fingers have the second most dense array of pain receptors in your whole body, with as much brain-space dedicated to your pointer as to your entire back.
The #1 densest? Your eye.
Which I think about every time I get a tiny speck in it...
Or how many guns were lost in that boating accident.Wonder what the captain had on Hillary
Simple. They don't Know any better!Whoever said "life is hard, but it's even harder when you're stupid" was wrong. All these stupid people I cross paths with seem to be perfectly happy and living an easy life.
Most news sources aren't mentioning that. I happened to catch an interview with a woman who said he was being bullied. I was shockedIf anything good came out of the Butler High School shooting, it’s maybe it will make some bullies think twice..they might get shot!
Motivation for the day:
We recently hired a new guy at work.
I haven't even learned his name yet,
Will is his name.Justin?
