Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
I've been acused of being a bad influence before...nothing new
@ponykilr Yeah, as long as they're hub centric, you'll be fine.
@iwaxmyjimmy You're welcome to use my drill fixture if you need to. I was looking at the specs on the Dodge rotors too, will they fit with no other modifications to the brakes? I ordered some Powerstop rotors and pads for mine, figured I'd go with stock application stuff so it fit better.
The bearings that were on this axle still felt nice and tight, so I drilled them. I'll probably pick up another set of new ones to redrill and keep on hand if one of these goes bad. I definitely like the ease of changing a unit bearing and how much cleaner it is...that and I don't have to worry if I got the preload right on them. They're also freaking huge bearings!
I'll be glad to get it put back together though, I'd hate to have to swap shafts or do ball joints again. Those big ass seals in the hub are neither fun to install or cheap!
Lol I seen that. I even went through and bench built it to see how much he had in it.
Sent from my iPhone using Tapatalk Pro
unit bearings for the win, especially in a frozen creek in Kentucky, in November... right @Paul?
Sent from my SM-G925R4 using Tapatalk
That was most definitely not my most stellar moment. At least it warmed up to 12 degrees by the time i replaced the broken knuckle.
I'll cuss too much. Let @mcutler tell the story.Oh share details lol what happened?
ummmmm not just no but heeeeeelllllllll no.Bc you're itching to put some won tons under the willys... might need another squirrel or two to turn them though. Lol
My 39th birthday November ride. Arrived Thursday night and it was about 10°. Freezing rain all night, about 5 next morning. Fired up the buggy and the regulator for air tank was frozen, used a blow dryer to thaw so the front ARB would engage. The ice on the trees on the back side of the mountain was "hanging" sideways... anywho...Oh share details lol what happened?
@paradisePWoffrd I know the 99-04s looked like they have an adjuster, but I don't see any way to do that on an 05+. The back of the bearings appear to be pretty much sealed up.
@iwaxmyjimmy The balljoints in mine were shot. Mainly just the uppers, but the factory ones donthave grease fittings, so they had to go anyway. The only parts I don't want to be greaseable are my u joints! I decided to use Mevotech brand joints over Moog because of recent concerns of quality after a bunch of buyouts Moog was involved in, but also because Mevotech makes the balljoints that The Dmax Store sells as their "Kyrptonite" line and they offer a serious, no questions asked warranty. After receiving them and looking them over, I'm pleased.
If you guys need part numbers or anything, let me know. I still have them for the ball joints, knuckle seals, diff seals, pinion seal, knuckle seals, stuff for the brakes, and the ball joint that's used on the axle side of the panhard bar.
Also, I think a guy I work with has one of those knuckle seal installers and from what I've read, they're a must have tool.
Last thing. Whoever designed the snap ring that goes on the stub shaft of these axles needs to be severely beaten. I cussed that thing like a redheaded step child for several days and through 4 different sets of snap ring pliers. It was harder than Chinese arithmetic!
The axle shaft u joints are your standard Dana 60 application, so no surprises there.
DIY Dana 60 Unit Bearing Drill Guide | Hired Gun Offroad
Found this the other day hopefully trying it out soon. It’s not a nice as @Croatan_Kid, but I’ve wasted 60 bucks on worse stuff.
The 450 and 550 axles are also 10 lug or the huge 8 lug pattern, so there's not much of a chance of mixing them up. If I'm not mistaken, you can swap the 1550 stuff in to the other axles, but I don't remember if the stubs are the same.
