Swampy go fast
The transfer nd case are in. Most of the clutch plumbing is finished. I'm going to work on the crossmember and install the front driveshaft in the morning
I was @ jeffs sun. he was still welding away.
even with all my projects. I may still beat him to the trails. lol
was this past sun. I know for sure where an xj and sucky... oops I meant swampy yota. was sitting at
I will take some pics tomorrow. I built a track bar for the front axle and finished welding the brackets tonight. I also cut down the twinn sticks and put my bud light tap handles on.......welded tube in the floor at the door ways to have a good place to run wires..
Shit still needed to be fixed......
Replace cut plug wire
Make a new trans tunnel
Order 1350 yoke for my front axle
Its going to be a few weeks before I can get the yoke so I'm going to put another 1310 joint in it........it might not break constantly now that there is a track bar to keep it from wraping so damn bad
I replaced the u joint, replaced battery, loomed the wirring, ran a larger feed wire from the alternator, made up some 2 and 0 g ground wires, getto mounted 3 tanks on the back, and mounted the high lift on the back.
I've drivin it a good bit in the past two days. The trac bar is keeping u joint from exploding...even during front digs. The only issuse that I had was the roll pin in the shifter broke. I'm going to drill hole out and put a bigger one in it sometime later in the week.
It kinda sucks that the truck is doing good and I'm too broke to go wheelin.....:(
Mine is ready......as soon as I fix the shifter and replace the bolts on the trac bar.
This hole in my floor is going to fun to cover
I should be at roberts....
If I can drumb up some gas money then I might hit up the Hell Trail on Sunday....If I do then there will be lots of pics.
