35xj
- Aug 29, 2005
- Asheville NC
best show on tv. I don't look so bad anymore
i don't know about that!
is it done yet?
I replaced the trans over the weekend. The truck cranked very easy on Propane. I still have to make a crossmember for the 205, do some grinding on my front driveshaft, and go over all everything/tighten bolts before the farm.![]()
U SUCK!!!!!!!!
My crossmember was bolted to the adapter and then had poly bushings at the frame rails...also poly motor mounts.
Danny, i've thought about that before, but I assumed if the engine and tranny were mounted the same way they should have the same amount of "play" or "give". Mine are mounted this way, you have me questioning it now though.
