Dylan W.
lone resident of Bro-Lite Island
- Mar 17, 2007
- Mocksville NC
On the side..where steps go.Liar. There's no way that's your TJ...
Where's the side steps?
Evidently out of your budget. Broke ring and pinion once 2 shafts and an ARB. Warped the heck out of the housing also.
Bigger shafts, carriers, ring gear
Says the guy with built 60s lol
And if none of that makes since fucking build that shit and walk that jeeps candied ass up Daniel or easy Street at the flats.
See above. Everyone else has already answered. What gearing is your jeep now? You can most likely find a 8.8 with the correct gearing in a junkyard for cheap. Thats how I did mine. I welded on new spring perches, hooked the brakes up and wheeled it.
Still calling April Fools/epic trolling...
Just need srw Hubs and good to go! Your taking this shit to serious brah... this is suppose to be fun while learning as you go, you asked about the strength of a d35 and you got a answer that wasn't what you wanted to hear from what I can tell or your young and just get your feelings hurt easily?? I had planned on a 14b under a Zj I've seen them under a few tj and ya know it looks pretty badass in my OPINION, but ya know what they say about that! Good luck with your dana35 tho...
If you are scared of Daniel then a d35 will probably be fine.I would never even think about setting foot on daniel.
Hey snowflake.again, I have stated that I don't want to hear anything but actual experience with what I asked about, which you obviously don't have.
Hey snowflake.
You don't get to tell people what advice to give you. You don't set the rules. This is a community.
BTW your registration profile says you are 38.
So either you lied when you signed up, or you ain't young , just dumb.
BTW who is Sarah4732?
Thank you very much for the advice. We plan on riding Daniel and dickey bell for sure. We do wish we could meet up with someone who knows the trails, but guess we will get by ok with a map and gps. I will definitely take your advice and try falls damn for a camp spot. Any one else have any input/advice for uwharrie? Thanks again for the input!
@rockcity
lmao. then shared with with the wife lol'd more. like every 10th post man. frikin awesome
@junkxj 1. dont be a vagina. 2. dana 35s suck.
seriouslly: i fought with every fiber of my being avoiding swapping axles. i researched hour after hour after hour - "dana 35 on 35s". To be honest, I found ALOT of people who had 35s on a stock dana35 and many who did chromo, locker and cryo; who did LIGHT wheeling (like a dirt round with some dips and whoops). They crawled this stuff, and then drove normal on the street. 4cyl, 6cyl, 8cyl.... almost every single one eventually broke. A few were still wheeling and saving going on 3+ years. There was wisdom in this: some of the ones doing stock, did so with a backup dana35 ($100) sitting at home. They did what they did and they saved up for a 8.8 or d44, or grandma's cane (something that was stronger than a dana 35). One guy... his dana 35 blew up the day he bought the last part he needed for an 8.8 swap (d35, chromo, locker). He went to take off from a light "boom!".
Anyways
If you want to be a good steward of your money. You need to do what you wanted to do, but also bombshell the tubes (sleeve them) and weld tubes and sleeves to housing. You also need to truss the tubes with the housing. Cryo the gears. Then it will be all good to go to handle 35s on up trails and street. This WILL be more expensive than switching to a 8.8 or d44. < FACTS. So if you are so concerned about cost but can not understand what is being told to you, go read an investment book
Listen. If youre too poor, then sometimes you just gotta sack up and do shit in stages. Swap in the axle. (lose 4wd). Drive it and do ride alongs until you got money saved for gears. Do the gears. Now enjoy better driving and ride alongs and save the money to do the front gears. Done. Do it right or don't do it at all. ITs not always just about money, but life. Our choices reflect our character. You can spend a week pissing in your radiator, or you can just go buy some frikin antifreeze.
Question for you. Why buy a "bolt in" 8.8? Super costly and you still have to do the "most complicated" part yourself and weld the perches/coil plates in after setting your pinion angle.
Except you already stated your going to do a full carrier and a regear either way so neglect that cost because it is basically the same cost as a 35. True talk look it up maybe a 100 difference. You don't "NEED" a diff cover you want one but the best is still only around 100 bucks but also the same price for a 35 cover. You don't need a new drive shaft you need a 20 bucks flange adapter, or you can be a baller and buy a new yoke for 120 but both still use a stock shaft. The only cost difference is the axle itself and an adapter. I've seen bolt in ready to go alxes on here for 400. A set of 35 aftermarket shafts are 350-400. Your also getting disk brakes with an 8.8Thank you for the information. For the most part everything you said was spot on. The fact of the mater is, I can buy any axle I would like to put under my jeep. If I thought a dynamic track 60 was necessary I would call them today and order one.
Buying a bolt in ready 8.8 is not expensive. I bought mine for less than the cost of the axle and bracket kit. The bolt in ready part I thought would be understood to have the brackets already welded I'm place, hence it's bolt in ready. The real cost are the gears, full case locker, decent diff cover and new driveshaft that was needed to finish the install.
Again, thank you for the info.
