NickMaul
- Jul 4, 2009
- Norfolk, VA
Long time no update, the more and more I work on other peoples stuff the more my junk gets neglected. It's basically been untouched since I changed the rear ring and pinion out. Did ghetto fix the leaks on the power steering resi, lets just say jb weld was involved but it doesn't leak any more.
Past weekend not 15 ft into the second trail the cross pin decided to check out on meAt least my dad got to drive it through the Honey Hole before it broke. It may have been on the limiter when I broke it
Tried to weld it but couldn't really weld the passenger side back solid due to the ring gear being in the way.
On the 2nd or so send the passenger side weld broke which basically let go. I could go back and re-weld it or put a spool but I despise these rcvs so much I'm selling the axle as is.
Which means as soon as I get room in the shop here in a few weeks it'll be One Ton time finally. I'm not going to be like other build threads around here and post a bunch of pics of cad or shit I'm going to buy because I don't have time for that. However my basic bitch TJ plans are as follows:
- 05 SD 60 Front (Spool, 5.38s, Stock shafts for now, has 1480 shafts may nab the 1550 shafts but we'll see.)
- 4 link front, 14" 2.0 Radflo Coilovers (not sure how well it will package but guess I'll find out) cheap poly bumps and limit straps
- 99-06 AAM 10.5 Rear (Spool/welded/Detroit (yo @D2320M you know you want to sell me the Detroit out of that 14b)) TMR shave
- 4 link rear, similar to what I'm running now just going to smooth the belly and triangulate the lowers some, 16" 2.0 Radflo air shocks, cheap poly bumps and limit straps
- Wheelbase Viagra
from 106" to 113-116"
- SMOOTH Belly, tired of hanging up on my link mounts. Going to weld weld some 2x2x.188 to the bottom of the frame and run 1.75x.188 dom across for the lower link mounts. Trans is already on it's on mount but it'll have to be redo since it's a Savvy
- Front frame chop, still undecided on how but I'm probably going to cut the frame at the first tub body mount, drink a Busch Latte and throw some tube and hot welding wire at it
- 17" Raceline's and 40" sticky Treps (I would go 42 and will eventually but not enough horsepressures or chromoly in the planed driveline to push them)
Why not run the sterling 10.5 rear if you are talking of welding the rear anyways? Are you converting your d60 to 8 on 6.5 pattern?
