Hopefully with enough heavy duty upholstery cleaners, passes with shop vac, the pressure washer, and carpet cleaner with some liberal application of elbow grease will bring it back?
This is one place where I vote buy brand new since you have the interior pulled apart already. It is amazing how much smell is trapped in vehicle carpet, and how much better the interior will look with fluffy new pile. Buy good stuff with mass backing and you will not regret it. A standard kit is less than $200, the "good stuff" is less than $300.
Transmission is in and cooler moved. Will do a URE shake down to verify no issues, then on to the 3 link conversion.
I have been making a list of everything that I need to fix on the wheeler once it cools down a bit. Amazing how these still cost money not moving LOL! Ordered up shock oil and some DOM to shorten up my air bumps because hitting them constantly on the way to the mall is annoying.
Put in some work last night on my K2500; I guess at this point it's a "mild restoration" since I'm in this deep
Started gutting the interior to deep clean, paint, and put in sound deadening
I didn't really clean this thing up before I parked it; I think October 2025 was the last time I drove it? Yuck
Pulled out the battery tray to repaint it before I slam the charging system back together.
It's pretty nasty looking and as I was doing that I started thinking about pulling the inner fenders out to free up some room, there's a broken exhaust bolt on the passenger side and since I've got headers to install the extra room would be nice
I'll probably wait until I start working on the suspension to do all that since I'd be right at it anyway
Deep cleaning the interior and getting everything freshened up shouldn't take too long, but the carpet is what is going to be a challenge.
Had a dude tell me he let all his carpets set out in the rain a couple time before he cleaned them......i was gonna try it on my Dodge carpet that smelled like wet dog but decided to just buy vynil replacent
Here's one place I was recommended, and while not terrible price wise most of my projects are on a shoe string budget these days
StockInteriors.com - 88 to 96 Ext. Cab FSC
The factory carpet has a couple of pretty bad spots but I've also seen worse and brought worse back. I may pull it and try my hand at cleaning and if I'm not happy with how it comes out then seek a replacement; my only concern is fitment
A buddy and I did something similar to a flip truck that smelled like a hog pen; left the carpet out on a trailer deck to air out and get rained on before we hit it with with carpet cleaner in a pump sprayer and a Hotsy pressure washer.
It cleaned up pretty decent and the funk was gone; a couple passes with a carpet extractor after putting everything together and aside from the sun fading it didn't look half bad
Ahhh, well
Heading back work from lunch yesterday I wad just crossing the railroad tracks when a lady in a new Tahoe cut the turn tight; so I veered to the right side of the street to avoid a sideswipe
I thought I cleared everything with no issue, but I must've nailed the curb next to the crossing signal
DA of the day:
I have been test driving and was able to get into 1st (unsynchronized) following Dom’s advice (gsndclys) and then to 2nd. But met a hard denial going to 3rd. My first thought was crap, I put this heavy turd together wrong and now I gotta pull everything to rectify this.
I have owned many manual transmissions:
Alfa gtv6 5 speed
Audi tt 6 speed
Porsche 968 6 speed
Golf tdi 6 speed
Tj 4.0 nv3550
Xj 4.0 ax15
F150 300 Mazda 5 speed
All were greater than 4 speeds, all the high gears required pushing the stick right before going back and forth.
So, with the understanding that I needed to push the stick right before going into the high gears I basically was putting the shifter between the reverse and 3/4 shift rail and hitting a wall
Being that the center rail is 3/4 it only needs to go back or forth. Shifts great no issues, wasted 3 days researching what could be the problem before realizing I was the dumbass of the day
So, not so much a da as I thought. Practiced 2-3 in the carport before driving, could only get into 3rd with a double clutch approach, but with tire drag slowing me down that resulted in being too slow to roll through the shift so I had to downshift again.
OpenAI says I probably don’t have full disengagement of the clutch , does that sound right?
I’m going to try a bleed on the slave cylinder, and then I have an adjustable pivot on the fork, but I’m smack dab in the middle of manufacturer recommendation, maybe incompatible pressure plate or something like that
Edit: tested master and slave 3/4”+ of travel at both (hard to measure) next step is to try adjusting the pivot ball
Almost finished pulling the interior on my K2500
I've been deep cleaning and refreshing interior pieces as I've gone; I've still got a couple that need a little bit of repair and freshened up but before everything goes back in I'll be throwing in sound deadening and thermal padding; unfortunately I found a few pinholes and not so great rust spots that'll need to be addressed but I'm still chugging along.
I ordered up a bunch of hydro fittings and hoses from surplus center. Hope to get the steering filter installed and all my barb fittings removed from my steering system and swapped over to -6 fittings this weekend. Hope to only have to carry a few standard spare length hoses and most importantly for safety after almost burning my truck to the ground on little Rubicon at GER when a barb fitting popped off at WOT.
Tow rig got all the fluids changed today. Hit 60k trouble free miles recently and decided to give it a proper service. It's had nearly 20k miles with my gooseneck behind it.
Fluids looked good, transmission was definitely ready to be serviced.
These have no dipstick and are a case fill with a standpipe in the pan to correct fluid level. Bought a $30 12V fluid pump to refill it. Saved nearly $300 by doing just the transmission myself.
Ready for another 60k
View attachment 459490View attachment 459491
What wheels are those?
My '27 is supposed to be here in 2 weeks...
So you think you missed the thrust washer?
I remember fighting to get the bearing to seat all the way, so I’m pretty sure that’s why it wouldn’t
Also, anyone wanting to install a temp sensor in the blanking plug on the passenger side head of an Ls motor for a standalone gage without an adapter
Vdo part number A2C59517248-S is the part number
M12x1.5 thread with sealing washer
Drove the Tacoma to work today, I was reminded of the drive line vibration that I forgot about lol. Add that to the list
