BRAIN DAMAGED TJ build
josh$$
FTA
Morganton NC
2004 Jeep Wrangler TJ
4.0 5-speed manual np231 with sye kit
2.5 rough country lift 1.25 body lift
Solid diff covers
soon to have a HP30 with 4.88 gears and a dana 44
Rocker guards built and installed by Buckeye performance
smittybuilt rear corners xrc front bumper and rear bumper with Buckeye performance rear tire carrier.
Steering box skid, radiator skid, skid row oil pan skid,
currie steering system with a antirock off-road sway bar
8,000lbs smittybuilt wintch
front smittybuilt tube finders and rear tube fenders
soon to have 4.88 gears with a detroit true track locker up front and already has a spartan locker in the rear.
It has 35-12.50-15 kevlars tires with 1.25in wheel spacers for clearance
now has a bestop nx frameless soft top
I picked up a HP30 to replace the LP30 Chris at BUCKEYE PERFORMANCE cleaned up the axle and man was it a mess he cleaned it and got it ready for new gears and gussets sleeve kit new ball joints and bussings
This thing will be a beast with the final mods, cant wait to see it in action! Youre new kevlars are 35,s arent they.
Before the 30th annual Dixie run I and Jason Watson installed new shocks cromos front and rear, Corbeau baja ultra seats (and brackets ).
Little carnage at the Dixie Run I bent one of the new shocks (replaced now) and busted my rear track - bar bushing (replaced)
Plus at the raffle I won one the sets of tire they were raffling away. So I got myself a new set of 35-12.50-15 BFG AT-KO2 tires .
X2 good to see this project keep going. What plans for the rear suspension setup and what are you going to do about the fuel tank? I assume your going to use Barnes brackets too?
Genright stretch tank the 11 gallon one. TMR TRUSS, FOX coilovers, and what ever Chris uses for brackets and mounts from Barnes.
Going with the 11 gallon so I can do a 7in stretch and have room for a one ton axle one day
I'd rather stick with 6" and get the extra 5 gallons, *especially* if you're planning on the Moab trip.
Does yours have the charcoal canister behind the right rear tire? If so what are you going to do with it?
It does and at the moment I have no idea what I'm going to do with it.im still reading up on it and Chris at Buckeye said not to worry about it so we will have to wait and see what happens
