StretchASU
Playing country music til Troy's ears bleed.
- Oct 17, 2006
- Claudville, VA
I mean, this is Fuller we're talking about...
A few pie cuts in a cherry bomb, welder back up and put that in place of the downpipe. Problem solved.
Thanks @Ron call him today. Came to work at 3 and nothing barely...putting to work in 2nd barely aarrrrrgggJohn look up Tim Stewart in Clover.
He is a great auto trans guy for the 4l60.
He is on agony acres Rd off hwy 55.
Good work and very very reasonably priced if you pull the trans.
this right here is the route that i go, hope to from the getgo, but for sure within time. and it's why I didn't mind getting these axles geared little bigger with leafs for good price (400...at least that is good price for me for D60/D44 8lug, geared little bigger, locking hubs,no disco). I know me, I won't spend money on gears or lockers, way too much cost for my current budget so when good/fair priced axles with anything in the 4:.. gearing comes along, it's what I go for. If I bought D60 F&R with 3:55gears than I would be stuck with that...probably forever lol.But HPD44's are pricier than pass drop and LP D44's, right? Get a D300 for about $250, sell the NP231 for $150, and then just bolt the D300 up. Clock it down a few degrees if the driveline angle is too much, or just don't lift it too high.
lol lol you said it not meI mean, this is Fuller we're talking about...
and @Jody about the can't flip the 231...
it's actually not that big a deal to extend the pickup tube and clamp it down on the inside to now pickup...you get the point. seen it done by many so
Not bad for 5 of them with aluminum rims for 300...worth 2hr drive and losing my transmission? No lol, but got it done! But new Tahoe trans is being put in so that's that
So u can't air down at allBe aware that those wheels do not have a safety bead on them... therefore, if you air down, the tire will come off the wheel.
Just keep an eye out for some cheap hummer wheels Recenter those rascals and rock out. and sell these if you do.
Long term shouldn't be an issue..231/300 doubler kits are readily available and should be in the budget within few months...I'm hunting for D300 now though since I have the $for it so I hope to find one by the time I get to that point of buildWell then, I am looking forward to seeing how you accomplish this with longevity.
Best of luck buddy
Had to go to Miller's transmission as everyone is 3weeks out OMG..these 4l60s suck lol lol, but they gave me several hundred cheaper than him and will have done in week. Thanks for info too...you should come by and meet sometime,..work on the rig too heheJohn look up Tim Stewart in Clover.
Well for now I can live with 15/20psi plus I've had enough low psi annoyance wout beadlocks so I'm good lolI wouldnt air down past 15 psi. And then it is still possible for the bead to be pushed off.
16.5" weld-on beadlocks not gonna work?
You could possibly do something like this, budget style: Crazy Internal Beadlock redneckstlye UPDATED - Pirate4x4.Com : 4x4 and Off-Road Forum
I've come along way but I'm on a time limit too since I'd like to finish it before midsummer to have time to ride...only limited amounts of "open rides" in a season so I fish around for best deal within budget and timeman you really need to learn how to use google before you waste your money on stuff
Easy man. I agree with the budget, but time? Come on. There are more places to take a rig wheeling than the flats or the SHOP that are basically open all year round. It can be hard to watch a rig sit on jack stands but it is part of the wheeling cycle.I'm on a time limit too since I'd like to finish it before midsummer to have time to ride...only limited amounts of "open rides" in a season so I fish around for best deal within budget and time
Plus you don't have to worry about breaking your own junk.Currently working on finding a D300 or np205 from what I read will work too...but might say screw it...wait and find the right Tcase and build the doubler from get go..either way I have the $for D300 so hoping to find one since will be needed in future plan anyway. Thanks and didn't mean to seem rude as not listening, I'm taking all notes in...I take long to respond sometimes while searching for parts and such. You find d300 before me LEt ME Know LolDo you understand that by flipping a 231, which has the pickup mount cast into the bottom of the housing, that it will be starving for fluid and cannot lubricate properly.
I know all about 231/300 doublers, I had one of the first ones back in the day. But I don't think you realize that you can't simply rotate the 231 180* and it still function long term.
There's way more to it than that.
My point earlier was since this is a budget build, spend your $$$ wisely. By installing a drivers drop front diff, you will alleviate additional expenses and aggravation associated with a pass drop diff in an XJ. Again, I've been down that road and have an idea what you're up against.
Not trying to be difficult buddy. But you probably would benefit from listening to some more experienced members before you slap that IH 44 up front.
All good info here..thank you..I'm hunting around for now...no time to work on it yet anyway lola 205 will be a terrible decision, imo. no gearing and wont be cheap/easy. Best bet for the 205 would be a Ford, then you would need to find a dodge 23 spline input or get an aftermarket one. The only pass drop option that might bolt up would be a dodge, but they arent easy to find. If you can find a 6 bolt chevy, it wont be cheap, and then you would still need the 23 spline input.
All in all, for the money you spend on a d300, you could buy a dsd d44 or SD60 and just run the 231 until you can put the doubler together.
Also, I would double check the ratio in those axles, if you havent. IH was never known for running deep gears in their vehicles, unless it was from a 4cyl.
If they are deeper, you could find a FSJ or 75-76 ford LP 44 and reuse the gear set in the other axle.
