marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
Was also referring to my hacked up track bar spliced with sch40 pipe that held up 1.5yrs..how's that possible? So I look at if that thin pipe survived that (track bar welded front = lots of pressure) than this double thickness square can more than hold up to the same usage (which this is less strain than track bar has on it)..hope I made senseDo you have some comparison to a known-successful tie rod made of square tubing of the same size you're using but with a thinner wall? I don't understand what you're
