CasterTroy
Faster'N You
- Mar 21, 2005
- Wallburg
For the price of off the shelf, I bet though somebody on here can build and design you a better working system for about the same amount of money.
Good gawd I'd HOPE so
This.Just a hunch but I bet most off the shelf long arms the geometry if you ran the numbers isn't that great. I'm not sure if you can find somebody that has done though them on the off the shelf kits.
I can't speak for most but from what I can tell, Andy builds his setups to function. He atleast looks at the numbers.Just a hunch but I bet most off the shelf long arms the geometry if you ran the numbers isn't that great. I'm not sure if you can find somebody that has done though them on the off the shelf kits.
For me, yes
I'd love to know more
What are you thinking @shawn ?
I don't want to go 37's. nor 4+" lift, and I'm not considering a stretch (way too damn much involved)
I'd like more options though.
I'm no expert, but I think it's a combination of "YES"Are you sure the arms were causing the issue? Not the sway bar, shocks, springs, etc?
Are you running a stock style 4 link or radius arm style lift now?
Goals are to be able to keep up with the rest of CTBers that are going all out haha. Seriously, going from the ZJ to the TJ has been great for most things, but I miss the wheel travel of the long arms, and in all honesty, for the rear I think a stretch will be order to get a little more back to ZJ. As far as spend, @CasterTroy said he was footing the bill so budget is unlimited![]()
I'm not looking to follow Mosteller up bounty hill, but if I could get a little more stability, I'd take it. Not gonna just piss away money though, so that's where I'm hoping you'll share your thinking
Just curious if there are benefits to doing a mid/long arm
Sounds like more drawbacks to LONG arm if I stay low and on 35's
I am not an expert on jeep suspension, but the factory setup is over constrained. On paper it will bind up during articulation because of it. Not sure how that actually plays out in real life or with stock arms vs aftermarket.I'm no expert, but I think it's a combination of "YES"
I'm running Ironman front and Rear. In fact...
Every time I build one I remind myself I'm not charging enough.Don't show Chris Ellis that price!![]()
Now if you just want to fuck with stuff and be different I would run a link mid arm (<30") 3 link setup in the front and stretch the rear to 99ish" with a 3 link as well. That's the current plan for my TJ no matter the axle nor tire size.
Hit 90 in mine once after you did the 3 link front for me and it handled fine but that bitch was screaming at about 4800 RPM’s if I remember correctly.Ok here is my theory on making it work.
Drop it off write down your contact info and wait for the call saying you have a badass jeep. After that all you gotta do is send the pics of the big cheesy grin you will have running 80 down the interstate with your pinky finger on the steering wheel or twisting it up on a rock ledge.
Sent from my SM-G930R4 using Tapatalk
Unfortunately, the way 2017 went for me my Jeep saw the most flex in their parking lot and not on the trail.
Look at 99% of buggies out there with a subframe. They appear to be losing valuable clearance. But the trade off is substantially improved suspension geometry when the link mounts are moved off the "frame" rails and placed in such a manner the link angles improve climbing.
@CasterTroy @BigClay - @Lee & @Cperry at ECGS hooked me up with some Clayton mid arms, Rock Krawler 3.5” springs, Bilstein shocks & a few other goodies. A huge improvement from the RC lift that was on there to start with. Unfortunately, the way 2017 went for me my Jeep saw the most flex in their parking lot and not on the trail. For the small amount of time I had it out this year I was thrilled! ECGS did an awesome job!
I'd be interested to see somebody do this with the Jeep on scales. How much weight is actually on that front right tire? There's probably some weight transfer due to the suspension geometry, but then? Maybe 200 or 300#?
Actually no. I have pictures somewhere in the office for record. I was testing the bump stops. Ordered longer ones and trimmed until the tire almost touched but to my surprise the springs never came loose.@CasterTroy in the picture of you crossed up in the swale in your front yard, isn't the extended spring loose in the
Boy you sure know a lot for.someone who never wheels outside URE and Big CreekYou may have more flex but a weightless tire does you no good for traction.
See now Shawn is onto the real problem with long arms on a tj. You may have more flex but a weightless tire does you no good for traction.
I've been other places too :flipiff2:Boy you sure know a lot for.someone who never wheels outside URE and Big Creek![]()
Bring it to Big Creek saturday and wheel so I can check it out![]()
