drkelly
Dipstick who put two vehicles on jack stands
- Mar 21, 2005
- Oak Ridge/Stokesdale, NC
Skip the D60 rear and use a 14 bolt FF.
And now for a couple of maintenance items.
The temperature sensor on the dash was not working. Turnout to be a sensor issue, so I swapped it with the one with on the 360.
After installing new shocks, it was noted that one of the 6 bolts that hold on the drivers locking hub was missing. The rest were loose.
A little research revealed that these bolts are notorious for coming loose.
Interesting thing about bolts and how they come loose can be found by googling
"Nord-Lock Wedge-Locking Washers - Junker Vibration Test" which is done in accordance with DIN 65151 standard
The video of a Junkers test shows how properly fastened bolts can come loose in ~30 seconds even if nylocks, spring washers, lock washers, double nuts etc are used.
Here is a picture of it works
View attachment 271815 View attachment 271816
I'm going to find 12 of these an try them. For Potts, I will just have to bring a socket and a ratchet to tighten the bolts to check things on the trail
The one I installed, [ Don Custer Special!] fit the same hole. I Did buy a 2-hole boot, & maybe slightly trimmed 1 side of the hold down ring, but it all fit the Factory hole just fine! Btw, I used the rounded boot, like in your kit.Parts are starting to come in...
One of the items on the list for the Dana 20 xfer case was the dual shifters.
Started to install them. One item I will need a floorboard cover that fits both the gear box and the xfer case.
Anyone have an extra one three hole cover like the one shown below.
The old two hole one is in good condition if someone needs one.
The axle's spring perches have 3 sets of holes to mate up with the springs.
Was thinking of using the middle perches for both the front and the rear.
Heard it can be advantageous to move the rear axle towards the back of the Jeep.
Thoughts on moving the rear axle ~3/4" towards the back of the CJ using the one of the other two sets of holes on the spring perches?
