Nice to meet ya Andy. Awesome truck, now get that winch on it!
It might have to wait until after the veteran's run, but it's gonna happen!
Not sure. Maybe just plain old bad luck? It’s got 175k miles on it, but I have no idea if those parts are original or not.Wow,
Any reason why all those parts are failing?
DoubleMint scared the shiz out of the kids and I today. I feel pretty lucky that no one got hurt. The kids and I were cruising down Stratford at about 45-50 mph when suddenly the motor died and the rear wheels locked up. I tried to hold it straight but couldn’t and we did a 180 across a couple lanes, ending up in the middle turn lane facing the opposite direction. All that was going through my mind at the time was “please don’t flip, please don’t flip, please don’t flip..”. Luckily it didn’t. I got out and took a quick look around and didn’t see anything funny with the drivetrain or steering. Then hopped back in and fired it back up easily and the rear tires seemed free. Limped over to the side of the road and coolant steam started coming through the vents. Popped the hood and saw that the idler pulley had come off the front of the engine and was wedged against the alternator pulley.
Long story shorter, I got a new idler put on to get home. In the process of replacing it, I noticed the tensioner is also about to let loose and the belt needs replacement. My JB weld plug blew on the radiator, so looks like it’s time to get the whole rad replaced as well.
I might not make it to the Veterans’ ride this coming weekend.
I have an aluminum radiator for my 99 I'll hook you up with. Won't fit my tubed frame rails.
PM if you're interested
So is this straight drive and the wheels locked up? Trying to figure out the relationship to motor stops spinning and the wheels break loose. Glad you and yours are ok.
if I had disengaged the clutch immediately after the tires locked up maybe I could have kept it from sliding
Holy smokes! Glad no one was hurt.
From the information given, it sounds like the motor locked up from overheating? Being a manual and the clutch engaged, the motor is directly driving the rear wheels through the trans and tcase. Once the motor stopped spinning, so did everything else.
Total speculation with that statement though
). Application was for a 2009-2015 Miata or a 2011 Porsche 911.Will you make the flats saturday?
I can get behind that notion....I made some serious job changes. I'll be contacting you.Highly unlikely. I'm pretty well overbooked for the next month at least and DoubleMint needs a repair or two before we go out again. Brake lights aren't working for some reason (probably the switch). What I really should do is go drop it off for @WARRIORWELDING to build me a winch bumper since I'm not going to be going on any rides for the next month or two. I'm getting tired of tripping over this winch that sitting on the floor in my garage.![]()
It was great to meet you. I am looking forward to see what you do with it.
