marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
Cool stop in sometime, I promise I'm not that crazy hahahaYou work a half mile or so from my house. I live near Hardee's.
If you're going to get another one under insurance might as well pay a few hundred dollars extra to get all the bows 3 foot on Center that would pretty much hold up along with the center 12ft braces and the corner 3ft bracing. Just a thought if you choose to get another one.I have a metal carport in the back yard that I used for camper and trailer storage. Unknown age since it was here when we bought the place 14 yrs ago.
This happened sometime Sunday morning.
Looks like the pop-up is ok ..... homeowners is gonna cover the carport minus the deductible.
I def would. If your not concerned about looks too much, use 2x3/2x4 for fraction of the costMakes me want to brace mine up after seeing all these.
That's most likely the 15g stuff. They all collapsed. 99% of these manufacturers use 15g for the average carport/building unless specified otherwise. Even then you gotta double check. I know of one company that claims 14g but it's clearly not. Just be ware
Think about that for a sec buddy... lol yepThat's most likely the 15g stuff. They all collapsed. 99% of these manufacturers use 15g for the average carport/building unless specified otherwise. Even then you gotta double check. I know of one company that claims 14g but it's clearly not. Just be ware
I know it sounds dumb but for what it's worth, none of his 14g stuff has collapsed or bowed from any customer. All 47sales that have come in since the storm are the thin stuff. Just by picking up a 6ft piece compared to our 6ft piece very noticeable difference in weight.So you're saying 1/128" of wall thickness means the difference between structural failure and awesomeness?
I don't get itThink about that for a sec buddy... lol yep
See also 2018 ford truck body partsIf 14 gauge vs 15 gauge (roughly 0.011 inches wall thickness nominal) is the difference between failure and not failure, that's a really marginal design.
Your right it's both. I guess I was saying all the buildings that have failed with or without bracing we're the thinner gauge material.I would really hope that the difference in number of failures has more to do with bracing and less to do with material gauge,
@Fabrik8 explained it well, the diff in those two gauges of metal are not the determining factor in failure I’m no metal expert, or engineer I assure you! I can guarantee that if you load up both gauges of metal, an test the amount of weight/force to cause failure to each of the thicknesses it’s going to be so minimal that it all leads back to design in this scenario. But once again I’m no engineer and I could be 100% wrong!? I’m basing this off my experiences with metal and metal stress. I’m learning just like you tho so I may get flamed for not knowing shit either!? LmaoI don't get it
Yeah I understood his point finally and I should've been more clear.@Fabrik8 explained it well, the diff in those two gauges of metal are not the determining factor in failure I’m no metal expert, or engineer I assure you! I can guarantee that if you load up both gauges of metal, an test the amount of weight/force to cause failure to each of the thicknesses it’s going to be so minimal that it all leads back to design in this scenario. But once again I’m no engineer and I could be 100% wrong!? I’m basing this off my experiences with metal and metal stress. I’m learning just like you tho so I may get flamed for not knowing shit either!? Lmao
