One of the things that was a must add before the next trail ride was a cage.
Since the CJ is not a bonce buggy and is just going to be for medium trails, and needs to be usable on the streets, what cage is needed?
A couple of other factors include a need for a harness bar, which means the rear seating option will be lost.
After looking at a bunch of different cages.
A lot of folks tie the cage to the frame.
One issue was a cage to frame route was the A-Pillar tube and the dash pad along with the 1/2 doors.
After talking with the folks at GenRight they have a solution for the clearance issues with the CJ
To get the clearances, GenRight recommended to go with their A Pillar kit.
Since John was willing to help build a cage, we both chipped in picked up a tubing bender and a notcher.
Then a trip to Race City Steel to pick up some sticks of 1.75" 0.120 wall DOM tubing.
John and I came up with a plan to build a cage that would tie into the A Pillar and B Pillar.
This is the result.
One thing that was discovered was if you weld the A pillar DOM to the A Pillar Kit, then it is not possible to easily remove the cage.
Since the cage has to come off to power coat it, those two parts are now designed to be bolted together.
One nice feature is the bikini top still fits.
The cage was inspected by the dogs and they approve.
Any thoughts before this cage goes to get painted?
