77GreenMachine
Phillip Talton
- Mar 30, 2010
- Mayodan, NC.
Reflective tape and a decal I had made really set it off. It looks brand new now from 15’ away.
We discussed "Stupid Hobby" at length Saturday morning and I thought it would be a winner. Now I'm sad.I see you were unable to convince the wife that it should say "stupid hobby" however I'm much more in favor of freedom![]()
I try to tell everyone that's never had a gooseneck how much better they are, but it takes hauling/owning your first one to really get it...
I'd cut the dovetail off or make it straight. Its hurting more than its helping.So today was a fun day. I came home early and made sure to do this in the glaring sun while it was super hot.
I got some tiny dollies and lowered the camper down into the back of the trailer.
My wife helped me, and we only debated getting divorced twice. Getting her to help me with things like this are always a good time. After some yelling and adjustments, some bricks, and several bottles of water, we got it lowered.
View attachment 321024 View attachment 321025 View attachment 321026
After I got it lowered I disconnected the truck and used the winch in the XJ to begin pulled it forward.
The dollies were small so I staggered them with the front on the passenger side and the rear on the Driver. This make it a little tippy but I was easily able to pushed in the bunk and manipulate it.
There was a point where it got pretty sketchy. The dolly did not want to go over the metal slat, so I had to gently let go and let my corner rest and use the floor jack to help it get over it.
We were taking our time and trying to keep it centered as we got closer.
The wife worked the winch. First time for me telling someone to “bump it” and it not mean “give it everything you got”
View attachment 321030 View attachment 321031 View attachment 321032
Then we got it past the fenders and I put the jacks back on for the last little bit.
View attachment 321033 View attachment 321038
I had to cut the side things just a bit to clear the front of the camper and the jacks.
Then I loaded the XJ for some test fitmant and a tow test.
View attachment 321040 View attachment 321041
I might know where you can get a good deal on the materialsSince we're already off topic anyway, I've been thinking about adding a dovetail to my deck over.
I don't think it'll be terribly hard to flatten out
add 2-3" of extra height at the axles
Wouldn't it be a hellova lot easier to
Wait you're agreeing with Shawn? Are you sick or something?
Imo not really no, if it were an enclosed with torsion axles yeah but it's sprung under leafs.
if I put the rollers on it won’t be a big deal
I'm talking about cutting the spring brackets off and welding a piece of tube to the bottom of the frame.
I'm talking about cutting the spring brackets off and welding a piece of tube to the bottom of the frame. If it's anything like a lot of these other trailers, there's a weak spot in the frame there anyway. It might be worth considering shifting the axles aft 6-12" at the same time to get some more pin weight. It should only take about a half day to do.
