Steve n Seagull?
I have that same album which also has the Nightwish cover on it.
It's hard to outdo symphonic/operatic metal, but a bluegrass band is nothing to play with.
Alright, gigs up... I'm a music nerd.![]()
How often do you get down towards Orangeburg? And what are you doing Saturday? There's a gnarly junkyard you've probably never been to calling your name.Nice. Ask him if he's familiar with Squadron 1.... Glad those parts laying around taking up space could help you my friend.
Demoing a storage shed on the MIL's property. I have a couple people lined up... could always use more hammers and hands.... Might even get to rent a mini excavator....How often do you get down towards Orangeburg? And what are you doing Saturday? There's a gnarly junkyard you've probably never been to calling your name.
Sounds like you're busy.Demoing a storage shed on the MIL's property. I have a couple people lined up... could always use more hammers and hands.... Might even get to rent a mini excavator....
Yes hopefully this is the last "project" over there besides cutting grass and things like that....Sounds like you're busy.
I'll let ya know how my day looks. I've got to restock on stuff from the junkyard. I'll more than likely throw the kayak on the roof with camping gear and make an Edisto river road trip out of it. Not sure who's gonna be riding with me yet.Yes hopefully this is the last "project" over there besides cutting grass and things like that....
It has to be Fuggin hot in there during summer! Nothing you can't handle, of course.We've got a film crew here with us today. We are working on a bench project for the city of Cayce that much like a lot of what we do, has never quite been seen before. This guy will be filming various stages of the project. CAD drawing, loading plate material onto the table, welding and fabrication, sandblasting and powder coating, and even install. View attachment 328045View attachment 328046
Oh, it is. Even our intensifier pump catches hell. The KMT 60 Pro we have takes city water (80 psi?), and after three levels of filtration, pumps the pressure up to whatever I set it at up to 90ksi. I'm currently running at 52ksi.It has to be Fuggin hot in there during summer! Nothing you can't handle, of course.![]()
That would be it.
but did you win?A sufficient rear driveshaft just got moved up on my list. I knew from the start that a Spicer 1310-1330 wouldn't last long, especially with 4.56 gears and the aggressiveness of a Yukon Grizzly locker. Pair that with a peppy 5.3 litre and a bulletproof 42 year old manual transmission.... BI-YYYYOWWWWW!!!! (Crunch, grind...FML) Drag racing that squat truck had nothing to do with it.
Coast, did I to a halt in a moderately safe traffic-free spot, jumped out with a 5/16 wrench in hand, pulled the rear driveshaft bolts to the T-case yoke, threw the rear shaft in the cargo area and skeeted back home in 4-hi glory.
Yee. Yee.
Spare parts for the win. I fully intend to take the boat out with my dad to enjoy a weekend in the swamp.
The LS Jeep life ain't no BS.![]()
At least up until I grabbed second.but did you win?
This pretty much sums up my Sunday afternoon.
A week or so ago I started noticing my rear 4-link brackets are starting to get a little sloppy finally. The lower link brackets are presumably A36 laser cut .25", while the upper brackets are .188 A500 (at least at the frame end). The A500 upper brackets have held up better than the lowers have. A500 Grade A has a yield strength of ~45-50KSI, while A36 has a yield strength of ~36KSI.
*Nerdy stuff I'll get back to later*
Saturday road trip: Hitting one of my favoritest junkyards for some driveshaft parts. I like stuff that I can't break. When I grenaded my rear driveshaft a week ago, I had to borrow some parts off my front shaft to get back on the road and most importantly, to work the next day. When I built this Jeep I knew the driveshafts wouldn't last long. It was one of those "throw a bunch of bullshit together and get it drivable" scenarios. Temporary, in other words. It required some ghettodaptation of everything from 1310-1350 and everything in between. The 1310 CV is insufficient. I've had to rebuild it twice already. The 1330 is a joke. A 1350 is borderline.
I stumbled upon a little gem while I was strolling around the junkyard. It just so happens to be the perfect length for the front, and with 1410 joints to boot. I'll have to order new yokes obviously, but this should do the trick.
The junkyard I went to was in the lovely town of Orangeburg SC. It's about an hour drive for me to get there. Across the Congaree and through a shit ton of cotton and soy fields, but hell, every mile behind the wheel of a Jeep is what heaven is made of.
Last time I was in Orangeburg went a little something like this. If you're wondering if it's acceptable to play on your cellphone while in booking, well... It's kinda not. Slightly frowned upon actually. Write that down. View attachment 329206
^^ old pic from a few months ago, for those speed readers out there.
Back to the nerdy stuff.
As a remedy for the hole slop I've been getting on my rear link brackets, I decided that some custom weld washers would be the ticket. All of my link bolts (upper and lower) are 5/8". I could've easily just ordered a full set of weld washers from one of our many online off-road parts suppliers, but with the excessive amount of scrap material just laying around the shop where I work, I figured, well I'll just make my own. We were recently working with a few sheets of A656 1018 3/8" steel. The yield strength of this particular alloy is upwards of 80-90KSI which is ridiculously strong compared to most typical mild steel. I thought it would be a perfect candidate for what I was going to use it for. There were 16 pieces cut total. 2" round washers, 8 with a 5/8" thru hole, and the other 8 with a 7/16" (which I later went through and enlarged to 17/32 and tapped to 5/8-11).
Tapping these to 5/8" was not easy to do. This is some very hard steel.
I hope so.Worth it. It’s all worth it. YOLO
