skyhighZJ
Thanks for your taxes
- May 31, 2012
- Aberdeen, NC.
Honestly just kidding take your time and put those rims together right the first time or it can be a total PIA. (Leaks)
this is the difference between the old me...ah just slap it all together and the now build me...plan it, think it, more plan it, try it...don't like it, plan some more (did I really just quote myself)well now I'm in with coffee and research....which is good so I don't go and rush into the uppers...need to figure them out....again dang it
Camera angle or beer....I'm not sure but that front axle appears to be welded into the shape of a poorly formed taco.All axle work complete. New ball joints, axle joints, barnes high steer arms.
View attachment 344469View attachment 344470View attachment 344471View attachment 344472View attachment 344473View attachment 344474View attachment 344475View attachment 344476
Build new crossmember, incorporate body mounts if they're there, cut out old one.@jodyou have a ranger/explorer frame right?..
Can I cut this brace out ...its in my way of upper links. Once I build the uppers, I will add in a new brace ...or not a good idea until new one built?
dang it was afraid you'd say that. well back to drawing boardBuild new crossmember, incorporate body mounts if they're there, cut out old one.
What did you do? Maybe it's adequatedang it was afraid you'd say that. well back to drawing board
haven't done anything yet...I'm wanting to cut that specific brace out...put my new upper links right in front of where that brace is to have my uppers be the same length as my lowers, 46", then build a new brace off the upper link mounts to tie the frame back together. to do it this way, which is the only way to make my upper links match my lowers, i need that brace gone first without adding in a new one in that same area.What did you do? Maybe it's adequate
You could always cut a slot and rebuild that brace in the shape of an arch inside the body.haven't done anything yet...I'm wanting to cut that specific brace out...put my new upper links right in front of where that brace is to have my uppers be the same length as my lowers, 46", then build a new brace off the upper link mounts to tie the frame back together. to do it this way, which is the only way to make my upper links match my lowers, i need that brace gone first without adding in a new one in that same area.
this build I'm trying to avoid doing any "hacking" on the body. wanting to do this as neat as possible. I have a few people wanting to see how this turns out without cutting up the body which could net me at least one more full build of exact platform if done well enough so yeah! otherwise I wouldn't be asking and have just cut away lolYou could always cut a slot and rebuild that brace in the shape of an arch inside the body.
yes true, but I think there's a way to do it here without sacrificing either and still making it look goodEverybody’s dilemma... sacrifices have to be made. Body or suspension. Something has to give.
Cut it out, build links, rebuild crossmember around them at full bump.plus in doing the uppers that way, not only do they come out even with lowers at 46", but they will be almost perfectly parallel at ride height which is golden!!. So I think I will weld in a temporary brace to hold the frame together, build my new setup after cutting out that factory brace then go and build the new permanent brace after that....this should work right?
Awesome thank youCut it out, build links, rebuild crossmember around them at full bump.
Hey, hey, HEY! Where's the character building in that? It's no fun if you don't nearly rip your own hands off when the ratchet strap(s) let go trying to get the run-flat back in the new tars. Kids these days....expect everything to come handed to them fully assembled on a pallet.It’s still “tonight” go get after it. Got good enough at one point we could break down, clean, and remount a set of 4 Good Year Mt on HMMWV rims in about 2 hrs. Of course now they come on a pallet fully assembled just zip lug nuts on and off. No character building in that!!!
That was scary as hell doing it on my last rig lolyou don't nearly rip your own hands off when the ratchet strap(s) let go trying to get the run-flat back in the new tars.
On this note, would putting a good thick bead of silicone or glue on the outside bead help with this or noI still run the magnesium ones on mine. Biggest complaint I have on my H1's is the bead gets mud and dirt in them too easy and they leak down because of it.
Good point..I miss the little detailsSomething else to keep in mind on the trusses - gotta either seal them up most all the way, or have vents in the bottom to let water/mud/etc out. Water is easy, but a hole for water will quickly get clogged with dirt and rocks, so they need to be ~1.5" or bigger. If you make plates for the other side, cut some fish mouths in the bottom edge.
Never tried it. I just break the offending one down once or twice a year and clean them. It's mainly an issue in the South I believe. IDK how other bead locks do with this issue.On this note, would putting a good thick bead of silicone or glue on the outside bead help with this or no
Seats. Cargo area will be shock towers. But I got it figured out thanks to Jody's adviceIt won't be hacking if it looks good. Is it beneath the rear seats or in cargo area? Figure out how to use it to your advantage...
