Jeffncs
- Apr 4, 2017
- Wake Forest
I’m a simple, cheap guy!!
There's a 575 also supposedly coming out that's 50w but has the buttons on the mic similar to the MXT275
MXT575 MicroMobile® Two-Way Radio | Midland Radio
Get the MXT575 MicroMobile® Two-Way Radio at Midland Radio. This radio comes with a fully-integrated control microphone for vehicles with limited space.midlandusa.com
You can get an 80W 2M for half that.
Link motha focka!!! Vaguebooking some beachYou can get an 80W 2M for half that.
A Yaesu 80W 2M mobile is about $175, IIRC. Probably cost another $50 in NMO mount and antenna, though.Link motha focka!!! Vaguebooking some beach![]()
If going GMRS only and if you want 50W, buy the Midland. It's ready to go out of the box. The ham radio solution isn't and may require some sort of modification and will require programming.
I just got mine yesterday.
If they do they probably dont work right! lol I finally took mine out and just run the Midland.I just got mine yesterday.
I came here to ask everyone's opinion. Should I keep my CB and add the GMRS, or just swap them out?
I really don't need the cab of my Jeep looking like a mobile tactical ops center. Does anyone still use CBs on the trail?
When we started to transition to gmrs, I had cb mounted in the jeep and handheld gmrs. It's a pain in the ass to be the guy that has both, because you end up relaying messages. I eventually replaced the mounted cb with gmrs.I just got mine yesterday.
That's where I'm at now. I've had a handheld baofeng in the truck for awhile.When we started to transition to gmrs, I had cb mounted in the jeep and handheld gmrs. It's a pain in the ass to be the guy that has both, because you end up relaying messages. I eventually replaced the mounted cb with gmrs.
Our club (Mid Carolina Jeepers) has moved to gmrs and several people have extra handhelds they pass out to those on rides without.That's where I'm at now. I've had a handheld baofeng in the truck for awhile.
Last couple times out, I noticed no one was talking on the CB. But I'm not running with a club. So, I was curious if bigger mainstream off-roaders/groups were still using them.
I'm a big fan of the VHF/UHF radios from baofeng and the like. They are stupid cheap on Amazon and programming them is as simple as cutting and pasting MS Excel worksheets. It's nice to be able to arrange your own channel list and have the ability to add repeaters, marine, ham, and weather stations to your list. Considering a base model costs about $30, you really can't go wrong with one.Our club has converted to GMRS. Hams can play along with FRS folks. CB is welcome but isn’t the main comms. To be in the loop requires someone with a dual setup. I honestly don’t think truckers use CB anymore, at least not like the old days.
I like that MXT575 as it’s similar in form to the CB I’ve had for years. Cobra 75 all in the Mic.
Like @77GreenMachine I see GMRS as simpler to understand and use. Easier licensing. Etc. I can see the VHF/UHF side of the argument too. Just lazy... or will be if I ever get around to buying one. ;-)
So here’s a question.
Just got a mobile unit, looking at where to install. Must radios, whether CB, Ham, GMRS all want a solid ground to the chassis and hot straight to the battery for best performance. To me that means less interference, perhaps less electrical power loss, etc. They’ll say you can wire into fuse box but I’ve never had good results from that.
So… what about a 12v plug? Would let me worry less about exact install location, but those wires aren’t normally very heavy gauge.
Thoughts?
Maybe, just maybe, that's overkill.
Wiring any equipment for a gauge that is adapted to the draw is probably the correct solution...
I have a midland unit, I just plug it in to cigar lighter and use the magnetic mounted Antenna, switch it to the tow vehicle when we caravan same setup 12" plug and magnetic antenna, no problems with interference or tuning.So here’s a question.
Just got a mobile unit, looking at where to install. Most radios, whether CB, Ham, GMRS all want a solid ground to the chassis and hot straight to the battery for best performance. To me that means less interference, perhaps less electrical power loss, etc. They’ll say you can wire into fuse box but I’ve never had good results from that.
Thoughts?
