- Mar 20, 2005
- Hendersonville, NC
1 week and $200 in parts and 2 hours of my life later, it's not fixed.
Replaced the motor mounts and tranny mount (age and seeing some play in driver's mount) with OEM ones (same as what it had prior) with zero difference.
Called @jeepinmatt and had a long, engineer-type conversation. We came up with a theory the rear yoke may be "off" and when the one driveshaft that ran smooth (but too short) was indexed on it, they somehow mated perfectly. So, I just swapped a new Yukon yoke on the rear- no different whatsoever.
The "good" shaft that had zero vibes is the one I dropped off at a local driveline shop to be retubed, so I don't have it as it was anymore. Otherwise, I'd have added a limit strap and rocked out.
I am replicating this on jackstands, at ride height, in 2wd. Swapped tires front to back just to see- no change. Swapped random driveshafts I have here- no change. Does not do it w/o a driveshaft in.
Andy at Ironman said the Rusty's UCA bushings (OEM style FVWIW) are notiously soft and could *possibly* be allowing the diff to rock even with a balanced shaft. Can't hurt, but I'm kinda done throwing parts at it.
This is absolutely infuriating.
Tainted love
