paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
Just so I am clear... directly to the battery, or to the main cutoff/disconnect?Correct. The constant connections go directly to the battery as per Holley
Batt positive and batt negative on the post. Referring to the 2 10ish gauge wires off the ECUJust so I am clear... directly to the battery, or to the main cutoff/disconnect?
Local Holley guru tuner guy said to isolate the switched 12 direct to the battery as a quick test. Goes hand in hand with what you stated.I havent messed with the switch pro units, but...I did trouble shoot and fix a similar problem with a buddy in a 5.0 (old school) in a hot rod running a holley sniper system.
Ill spare you the gory details of how much shit we chased, but his (again stressing wasnt a switch pro unit) was caused by EMF noise coming from the LEDs in the switch system panel.
Started troubleshooting with wires direct to battery and shit cleaned up...then broke out the scopes to understand why.
This is what I have done with other Holley systems, but those were in street cars. Are you going to run a battery disconnect on it? If so, what is running through it? Just switchpro? Maybe starter trigger? I know these are kind of stupid questions, but trying to understand how folks are wiring rigs these days, since I will be rewiring before long. In the past, my rigs ran everything through a disconnect, but they were minimal wiring with carbs or lpg.Batt positive and batt negative on the post. Referring to the 2 10ish gauge wires off the ECU
Good questions.This is what I have done with other Holley systems, but those were in street cars. Are you going to run a battery disconnect on it? If so, what is running through it? Just switchpro? Maybe starter trigger? I know these are kind of stupid questions, but trying to understand how folks are wiring rigs these days, since I will be rewiring before long. In the past, my rigs ran everything through a disconnect, but they were minimal wiring with carbs or lpg.
Good questions.
There is a battery cable from + to the disconnect. Output of disconnect goes to starter solenoid feed side. Also on the output side of the disconnect is the supply to starter switch and 6 gauge power supply to SwitchPros unit.
Yes, the constant power to the Holley is direct at battery and not effected by the disconnect. I did this since Holley clearly states go direct to battery. After I'm all done getting it running, I'll run the constand 12 to the disconnect and make sure it does ok there. If not, I'll leave at battery.
Already done so. Ford uses the PIP output as a cam sensor signal, then doubles it to calculate crank speedMight be a pain to do but check continuity on the wires going to cam sensor. Move the cable around with the leads connected. The vibration of the motor turning over might be enough to disrupt the connection.
The main cutoff of using large enough cable is the same as direct to battery. You must weld cable for this to be true, but equivalentJust so I am clear... directly to the battery, or to the main cutoff/disconnect?
that little pip squeak is getting on your last nerveAlready done so. Ford uses the PIP output as a cam sensor signal, then doubles it to calculate crank speed
I have consistent voltage output from it.
No.The main cutoff of using large enough cable is the same as direct to battery. You must weld cable for this to be true, but equivalent
Have spark, have fuel, just not coinciding appropriately.I'd love to but I'm terribly swamped right now
You don't have a good tuner guy that could do it ?
I have a few recommendations but they're a ways out from you.
First thing I would do is isolate all the systems from the switchpros so you're not fucking with this on top of the rest.
Do you currently have no spark and/or no fuel ?
Probably even have a dream about it.Gotcha. Is your ECU controlling timing ?Have spark, have fuel, just not coinciding appropriately.
I would have been surprisedI did isolate the circuits with no change in symptoms.
SmartDoing a little research so I have a game plan when I venture back into the shop
ECU controls timing beyond the base timing.Gotcha. Is your ECU controlling timing ?
Smart
oui, ouiI'm assuming you tried to lock the timing in the software and start it up as is ?
With a timing light on, what does timing read then?oui, oui
Balancer is marked at 15* BDTC at #1 and then again at 90* increments. Going down the firing order, each cylinder fires at it's appropriate sequence on it's mark.With a timing light on, what does timing read then?
dumb question.
Hows the battery?
Im throwing shit at the wall and haven't dove in to diagrams on this. But Ive seen issues before (even on very expensive industrial equipment) where a sensor has a very tight voltage tolerance and drops out due to voltage sag while cranking. Wonder the operatign range of the cam sensor
Same thing happened with Megasquirt if voltage was less than 10dumb question.
Hows the battery?
