awheelterd
- Oct 18, 2007
- Kenly, NC
I thought I had bought 93sNow you know why studs come in 93s...when you figure out the 92 5/8s tell me so we both know
FWIW, I started trying to find my old spreadsheet where I calc'd out the beam in my loft, then got distracted by pretty much anything, and never got back around to it.Since you buzzards wouldn't bless me with your brilliance, I kept googling.
Or just hand him the steel manual and let him do the math himself. No reason to make yourself liable.FWIW, I started trying to find my old spreadsheet where I calc'd out the beam in my loft, then got distracted by pretty much anything, and never got back around to it.
Or help a friend out and not live in fear.Or just hand him the steel manual and let him do the math himself. No reason to make yourself liable.
Assuming that pad was 20x30, what was the thickness? Trying to figure out ahead of time whether it is worth pursuing doing my driveway this year.
The PL company doesn't care who it ishelp a friend out
You'd have to check the fine print, but that's probably based on a 40psf live load. Make sure whatever it is actually matches your use case.View attachment 433430
Because this beam will be supporting one side of my 10" loft, the tributary load will only be 5' if I'm reading this correctly. 6' tributary load is ok for 20' span so it looks like I should be good with 1 post in the middle. I'll report back it it all falls down.
Neither does physics.The PL company doesn't care who it is
Yes, 40psf live load is what I was using. What would you suggest I base my numbers on? I don't forsee storing thousands and thousands of pounds up there. I have warehouses for that.You'd have to check the fine print, but that's probably based on a 40psf live load. Make sure whatever it is actually matches your use case.
I don't have an opinion on the matter, just wanted to make sure you were aware. Some folks might see that chart and then plan on storing pallets of old blocks and heads or rows of shelving stacked with who knows what "up out of the way".Yes, 40psf live load is what I was using. What would you suggest I base my numbers on? I don't forsee storing thousands and thousands of pounds up there. I have warehouses for that.
Thanks for the heads up. This will be more for Christmas decorations and junk like that. Possibly a hangout are for the kids with a pool table and foosball table in the future. 8' pool table would be the heaviest "thing" that would ever be up there other than live weight. It would be situated the long way so not too much of a point load in my mind. I've got a few spans of pallet racking I'm putting up along another wall for storing heavy stuff.I don't have an opinion on the matter, just wanted to make sure you were aware. Some folks might see that chart and then plan on storing pallets of old blocks and heads or rows of shelving stacked with who knows what "up out of the way".
As a point of reference, typical office loading is 100psf (though vibration often controls) with 200psf or more used in places where high density files or other concentrated loads might be. 100psf might be high if you actually do the math, but it's to allow for unknowns down the road.
Stairs + Pool Table = Not Enough Beer In the World for me to help you get it up there! An 8' slate table is ~1000# plus.Thanks for the heads up. This will be more for Christmas decorations and junk like that. Possibly a hangout are for the kids with a pool table and foosball table in the future. 8' pool table would be the heaviest "thing" that would ever be up there other than live weight. It would be situated the long way so not too much of a point load in my mind. I've got a few spans of pallet racking I'm putting up along another wall for storing heavy stuff.
ForkliftStairs + Pool Table = Not Enough Beer In the World for me to help you get it up there! An 8' slate table is ~1000# plus.
It made a world of difference. Pulled it maybe 1/4 mile down the path to my buddy's shop to weld up the tongue, prebrace, and it was some serious tail wagging the dog syndrome. Slapped the longest piece of angle he had up there and it was night and day different.This feature here is so much more important than most people realize:
He still using my channel iron pieces to bolt the 6x6 to the excavator knuckle? I can almost see them in the last picThese pics are a couple days old. They're over halfway done with the roof now.
View attachment 434953View attachment 434954View attachment 434955
He still using my channel iron pieces to bolt the 6x6 to the excavator knuckle? I can almost see them in the last pic![]()
