Even 20 years later, H2 wheels still look good on anything except an H2!It’s far from finished but it’s off the jackstands and sitting on the suspension. Still a long list of stuff to check off but it’s cool to see it back on the ground again. View attachment 436006View attachment 436007View attachment 436008View attachment 436009
Looks great man. I love it. Nice work.It’s far from finished but it’s off the jackstands and sitting on the suspension. Still a long list of stuff to check off but it’s cool to see it back on the ground again. View attachment 436006View attachment 436007View attachment 436008View attachment 436009
Thanks man. I’m pretty happy with how it’s all turning out so far.Looks great man. I love it. Nice work.
Get a couple wall mount ladder hooks from Lowes Depot and screw em into studs on the side wall. Even if there's a workbench or something in the way, set the difficult end on first, then hop down and set the easy end on.Thanks man. I’m pretty happy with how it’s all turning out so far.
Ran out of 1.5” tube yesterday and I was down to some random shorter lengths of 1.75” so I hooked up the trailer and took a ride to Stock Car Steel. Kind of slim pickings in the drop rack for what I needed so I bought a full stick each of 1.5” .095 and 1.75” .120 DOM along with a couple 1.5” .083 drops. I need a better way to store sticks of tube before I cut them. The only way I’ve found to get them out of my way is to hang them from the rafters but that’s a pain too. Just dropped these in the middle of the floor since I’ll be cutting pieces off to finish out the front. View attachment 436098
I’ll probably do something like that once I close the front of this building in. I’m pretty much working under a 12’ tall carport right now with closed in storage behind it. 40x45’ roof and slab but only the back 20x45’ “back” is enclosed. And there’s a tack room built like a building inside a building taking up a big chunk of that space. It was built as a barn with covered parking. My plan is to put up walls and a pair of roll up doors but I’m making it work for now.Get a couple wall mount ladder hooks from Lowes Depot and screw em into studs on the side wall. Even if there's a workbench or something in the way, set the difficult end on first, then hop down and set the easy end on.
Stock Car Steel just called and said my order was ready for pickup. I just got 4ft lengths for my links so I didn't have to deal with 20ft lengths.Thanks man. I’m pretty happy with how it’s all turning out so far.
I figured that if I had them cut it in half I’d end up needing a piece like 6” longer than what I had. Some of it is going to be the front of the roll cage so I’ll need some longer pieces for that.Stock Car Steel just called and said my order was ready for pickup. I just got 4ft lengths for my links so I didn't have to deal with 20ft lengths.
I’ll do that once I have walls up. If I did that right now it’d be the same as just leaning them against the outside of the building. The roof being 12’ up means if there’s even a breeze along with rain, everything is wet.I have some 12" shelf brackets on the wall at my shop. There is a tube of 1.75 and some 2x2 on it now. Works great and I've had 4 or 5 20' sticks on it.
That’s pretty cool! It was a good little ride when I had it. It got changed up a bit after it left me and last I heard it’s out west somewhere now.cool build!
CRAZY. i built that tube buggy maybe 20 years ago!
i cant believe how many times its changed hands, and still going strong!
I’m super happy with how they look. I’ll take a pic of the wiring conversion pieces my buddy gave me to make the 2 wire lights function as turn and marker lights off the 3 wires the TJ uses. It’s intended for semi trailers to do exactly that. I was gonna make a conversion harness with diodes and resistors to do it but these are ready to plug in and work.I’ve been planning to do JK turn signals in my grille, but I REALLY like those. Going to look into that. You have a link for the bezels?
I found them. Definitely doing this!
Awesome, thanks! I bet they're like what I had to buy when I put a flatbed with LEDs on my Dodge a few years back.I’m super happy with how they look. I’ll take a pic of the wiring conversion pieces my buddy gave me to make the 2 wire lights function as turn and marker lights off the 3 wires the TJ uses. It’s intended for semi trailers to do exactly that. I was gonna make a conversion harness with diodes and resistors to do it but these are ready to plug in and work.
Here they are.Awesome, thanks! I bet they're like what I had to buy when I put a flatbed with LEDs on my Dodge a few years back.
Thank you!
I’m not finding them now either? A month ago they were popping up for $15ish each. This is about the closest thing I could find to what I have.The part# on that Grote adapter didn't turn up in a search, but I found these that should do the same thing.
https://www.amazon.com/Custom-LED-Blinker-Genie-Automobiles/dp/B07DQRPRLW
What size is the radiator core? I have a nice blank aluminum shroud from my buggy build that I didn't use because I needed a deeper one for the Volvo fan. I think it's for a 22x19 radiator.
