Lawn Care Cab and Chassis build
Oh and when it is 20 degrees you have to pre heat stuff
Air compressor was not happy until I warmed It up
Back at it
He used the forge to make some custom parts
View attachment 451958View attachment 451959
That is cool!
On that forge - you need to coat that “wool” with a layer of heat resistant cement/ceramic stuff. Supposedly that stuff can be bad to breathe, similar to asbestos. The forge is blowing on it and circulating little pieces for you to breathe in.
That is cool!
It was coated. But probably could use another coat
On that rear gate, why not just weld the square tube across the bottom instead of through, with all the cuts and whatnot?
No way to add springs to that gate so to avoid the complexity of the winch, power source, remote, etc at every job?
Just curious, as I would not have the patience for all that!
He did not want a spring. He liked the winch idea and he is stubborn so not worth the argument, I am betting he will change to springs some day :)
The gate has 2 sections. Section 1 is 6feet and section 2 is 3 feet. For a total.of 9 foot ramp, which would be to tall to drive around with
He made 2 more gates that drop down so you can load from the side
He is thinking pallets, etc
All major fab is done, tomorrow we bed line
I'm just curious.....as I used to run a lawn care co.
Was there a discussion of having a trailer and truck instead of a cab/chassis? So much livelyhood tied to the drivetrain of the van
oh we had a lot of dicussion he (18 year old, wiser than me) said this is what he wanted and he had the money to do it. So, this is where we landed. :)
he still has his trailer he built: Sons trailer build
so if van has issues he can use this truck he also built: Corbin's Comanche to tow the trailer.
