That is cool!
It was coated. But probably could use another coatThat is cool!
On that forge - you need to coat that “wool” with a layer of heat resistant cement/ceramic stuff. Supposedly that stuff can be bad to breathe, similar to asbestos. The forge is blowing on it and circulating little pieces for you to breathe in.
He did not want a spring. He liked the winch idea and he is stubborn so not worth the argument, I am betting he will change to springs some dayOn that rear gate, why not just weld the square tube across the bottom instead of through, with all the cuts and whatnot?
No way to add springs to that gate so to avoid the complexity of the winch, power source, remote, etc at every job?
Just curious, as I would not have the patience for all that!
The gate has 2 sections. Section 1 is 6feet and section 2 is 3 feet. For a total.of 9 foot ramp, which would be to tall to drive around withOn that rear gate, why not just weld the square tube across the bottom instead of through, with all the cuts and whatnot?
Look out Jesse, Heisenberg has a temper
oh we had a lot of dicussion he (18 year old, wiser than me) said this is what he wanted and he had the money to do it. So, this is where we landed.I'm just curious.....as I used to run a lawn care co.
Was there a discussion of having a trailer and truck instead of a cab/chassis? So much livelyhood tied to the drivetrain of the van
Started bed line
Don't worry I told him that storyGot to watch that stuff. It's a pain if it gets on your hootus.![]()
No mcd’s brekky drive thru with this guy
As someone who worked in a paint factory for 17 years, I can tell you the secret for any future accidents.Well I screwed up today. Was shaking gallon of paint and handle broke and spilled 3/4 of a gallon on shop floor. Sand and kitty litter helped. But what a mess
