not quite.......... interior is gutted and dynomatted, tranny tunnel is done, tranny is in, its wired, however...............
My chevy tranny theroretically won't work w/ a dodge input shaft you have to have a HD version I guess. I could have torn tranny down bored case re-drilled and re-tapped the case, or get a new case swap internals over. My solution was cutting the noses off of the two input bearing retainers, opening up chevy one to allow the dodge shaft to slide through and tigged the dodge nose to the chevy input bearing retainer. Kinda long description ill post some pics when I can.
My other problem is its wired but I wasn't sure about the tach and was leaving it until the end, I did notice on the chevy wiring diagram that it appeared the tach signal was coming from the altenator but I brushed it off, the chevy had a crank sensor so does the dodge, unfortunatly Chevy 6.5 uses the altenator to run the tach, Dodge uses a 8v hallffect sensor and runs it through the computer ECU interpoates and sends it to tach which means im going to have to build a bracket to run the chevy alt. or run an aftermarket tach, and i don't want to run an aftermarket tach. the other solution, which may or may not work is taking a dodge tach out of an instrument cluter and opening up chevy cluster and installing it. But have no idea if this possible and I sold the truck so I need an instrument cluster to try this if anyone has one, this is the solution I want to try first.
I went to start it a week or so ago and my batteries would not budge the motor, so i got some new ones and the Cutoff soleniod is bad, half way expected, but then the lift pump is also bad. I mean really the best thing about this motor mechanical lift pump that rarely fails failed.
So ill post some more pics but need a lift pump, shutoff soleniod, and more time.
As for the wiring Everything is wired in Wait to start light, fuel filter maintence light, check engine light, speedo, coolant, oil presure, Cruise control factory dodge spliced into the chevy using the dodge vacumm pump.
