- Mar 20, 2005
- Morganton NC
So if im only running regular seat belts i cant run 2 of the trails?? I have a full exo and you require a helment. I dont see the need for a harness.
The Harnesses cages,and helmets are only required for TWO trails.
One of these trails(No Way) will never feel your rear tires on it's face(my gut feeling)and if it does, you will be on your lid (again, my gut feeling, based on my knowledge of this trail)
The other one, Sky trail, named for it's exit(you will see nothing but Sky and tree tops if you make it that far on exit) could suck you in as it's doable at the bottom. I also predict many flops coming out of it.
I won't be using shoulder harnesses or a helmet during this day because I have nothing for either of these trails! So if you stay where I will go, you will be fine.
As Kevin said, you WILL change your tone once you have seen them.
