Swampy go fast
Well you can use the winch to get it out of the basement if needed. :lol:
Feels good to get it close to wheelable doesn't
I still haven't put a receiver in the back of my truck yet....So the winch would do me no good in getting the truck out of the basement.
It feels pretty good to make it this far......lt has been a long time in the making.
I caught up with Ryan from 4 wheel parts this evening....and he had my warranty replacement shocks...
When Ryan left the store the other night he told me he was meeting some guy with a beat up old Toyota like mine. Little did I know. :flipoff2:
Yep...The only reason you have more dents than me is because you have more sheetmeal:flipoff2:
So you work at 4WP? Are you the one who bought a Toyota axle from me a while back?
Yes sir to both. Next time you, or anyone for that matter comes by, bring up NC4x4 and save some coin.
:beer:
Did you ever figure out what was wrong the 4wd in your dodge?
I put my kill switch on this evening so now I don't have to pull the wires off the battery terminal. I'm going to fill the trans here in a few minutes and I might back it out of the basement and drive it around the yard a bit.
I got the trans filled up and it actually moves easily now. I wanna take it for a test run but I will have to wait until tomorrow. :( Damn homework.
I'm going to take it for a spin in the morning before I take my dodge up to L&N to get a check up.
Call a brotha. Go get some eats while Lucas checks out the Dooodge.
I'm going to test drive it right now.
Well? An hour is long enough for a test!
Found a vacuum T connection had popped off. Fixed my 4WD, cruise control and stopped the ABS and Parking Brake lights from being on all the time. Figures it would be something that insignificant. :rolleyes:
Ok.....
I new to shim my ps pump so the belt lines up exact...belt came off
my front driveshaft is hitting my exahust....I'm gonna have to add a spring to the pack to lift it a little. The added weight of the v8 is killing it
I need a new valve for my propane tank
I need a shift knob....shifter cut my hand
and.....
Front digs are the shit!
This thing continually tries to ruin my life......It won't crank for shit now.
Anyone whose good with propane and chevy stuff wanna work on it? I'm done with this. I'm ready to pay someone to fix it.
I'm almost certain that something is wrong inside the mixer. If I had more time tomorrow...I'd put the 750 back on it and see how it does.
It cranked again and ran well.....then died and won't crank back
Write your reply...
