WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
it may just be a difference in terminology; but i caught alil flack about some mig triggering welds( or tack-tack as they called it) on my sheet metal in my copper crawler build, here and on pirate. warrior welding gave me some very technical input on the downfalls of this method, which sounded logical to me, yet i see this everywhere from garage builds to full custom shop builds, and no mention of any criticism on those.
I stand by my advice, and I believe the only reason it was brought out was that the original pic was on a tubing member of some sort, not sheet metal.
The tack tack method is not ideal for anything structural because you get a cold lap between each tack. IMO for what you're doing with all the sheetmetal thats not so structural its fine but not for much else. If you were to cut a triggered weld in half lengthwise you would see that there is a gap or small hairline crack between each tack.
If you prefer to have that nice dime stack look. Practice doing a continuous weld and varying your pattern. I typically use lower case cursive e's and change their over lap and height based on the look I want and the material I'm working with. Works for me in any position, pushing or pulling. I always picture that I have margins to touch as I make the circles just like having to type between the margins on paper. Focus on the margins always go up and down the same amount so you get that nice uniform bead. Once you get that down you can work with different amounts of stickout and how far you dip back into the puddle to really tune the weld like you want it. It's kinda like a golf swing, you've got a hundred things to do and think about but the more you do it the more natural it'll be.
One hundred percent agree. Good practical advice.
Here is a theory....
If a chassis was built structurally sound and all of its tube continuity was perfect, it would most likely live a super long time and take tons of abuse with shitty welds....
Disagree, poor welds fracture and or fail catastrophicly.
Therfore the chasis fails. The only thing that holds a poorly welded chasis together longer is poor over engineering to hide badly constructed joints.
on the other hand
If a chassis was not built structurally sound BUT had perfect welds it would most likely crack up and fall apart....
Nope the whole unit would act as a reinforcing structure. The entire stucture may fagtigue and show signs of stress and break down, but no single point failure should ever occur.
I disagree that trigger welding is a bad thing.... Not only was I taught to do it in school, but I have been around multiple sand car companies, and trophy trucks for that matter that trigger weld everything....
Trigger welding is a bad thing when someone doesn't understand what they are trying to accomplish other than it looking cool.![]()
Triggering a weld and or "MANUAL PULSE WELDING" is entirely a different process than tac tac tac tac ..................
Think about it like this.... On .120 wall tubing to get a perfect weld all you have to do is get complete penetration past the .120 mark on both pieces.... So if you make a bead thats not undercut, no matter how you make your bead.... Look at the back of the weld and you can see the filler in tact all the way across, you have accomplished your goal....
Just because you see penetration doesn't meanm the jopd is done.
If your welding a 3/8 steel plate to a .120 wall tube.... Chances are, your not going to get the right penetration any way you go about it.... It all goes back to fabrication and chamfering the edges on that 3/8 plate
Trigger welding takes around the same amount of time and preparation as tig welding does in my opinion.... Plus its always good to know a few trade secrets![]()
A properly preped joint shouldn't need to be manually pulsed except in high current vertical up travel.
Practice makes perfect and this type of welding definably takes a TON of practice and is the hardest to get right!!!!
I'll agree with you. Yea it is probably strong enough to hold up forever if you do it right. The fact of the matter is that a trigger weld and a continuous weld compared side by side the cont. weld wild always prevail.
With all the bad blood that comes with trigger welding and the fact that the AWS doesn't even recognise it as a legit weld procedure why would a big trophy truck or buggy builder even think about doing it. To me on tubing a continuous weld that looks like a stack of dimes is much more complicated to make look nice and be stout than stacking tack welds up on top of each other. Seems like an easy way to make a "stack of dimes"
I understood everything you said here except the last statement. As for the stack of dimes- individual dimes want buy squat. Tie em together and you can buy a coke to drink. Forget about trying to make everthing look all lapped together when your mig welding tube and you can make dollars. People really should stop trying to make Mig look like Tig.
