- Mar 13, 2005
- Raleigh, NC
That's at metal/metal contact. Bump height should be an inch or so lower than that.
If I end up with new tires on the lake bed, they'll have to be 37's any way....no problems in clearance there!What happens when you get new tires on the lake bed![]()
[emoji106]That's at metal/metal contact. Bump height should be an inch or so lower than that.
Where is the dimple die holes at?
He should up it on this one and do dimpled ovals.Where is the dimple die holes at?
Don't forget all the stickers on the back glass it will make it faster
Ok, I have to say the first few pieces of cardboard template didn't impress me like everything else has. But you completely suprised me by the last couple pics. Your 10 pm post was eh, but by 2 am it was BAM. Do you have a idea of what the final look is going to be when you start or is it a step back an ass scratch kind of process?
Either way these should not be covered up. They're going to look badass popping through the hood.
It is an intake!, forced air intake for shock cooling......[emoji33] lmao.Don't take this the wrong way cause those mounts are bad ass. And for the people that wheel will know what they are and appreciate the fab work, but for the people that don't know what they are for at the gas station if they come threw the hood like I'm imagining they may think they are some kind of air intake
Thanks mac.Awesome work Matt. What thickness plate are you using for most of the plate work.
Thanks mac.
Generally .120 p&o. The base tabs on the rear upper shock mount was 3/16, and the laminate overlay was 14 gauge. All the front shock mount is .120, so far. Both sides of every shock mount have a 1/4" ruffstuff weld washer. Everything gets all edges polished with a red scotch brite pad, then d/a on all plane surfaces. I spend a lot of time laying straight edges on the edge of workpieces to have straight, clean welds. .....Oh to have a plasma table...but then I'd have to learn to use it...[emoji90] ain't nobody got time for dat!
Matt
Thanks mac.
Matt
