sammi_davis
Sawzall Surgeon
- Oct 23, 2005
- Eden N.C.
Where did the steering wheel cover come from? Looks much nicer than the slip on version.
It is a slip on, thin, neoprene cover I got at WM for like $7.Where did the steering wheel cover come from? Looks much nicer than the slip on version.
Damn Martha Stewart...I got 3 you can come do for meI take upholstery thread (heavy 100% nylon) and stitch them on like the factory cover is. This is the 3rd one I’ve done.
You need to use a scan tool back and tell you if the PCM is seeing the cruise control request. If it is not seeing the request you very likely have a bad clock spring.Measured for bumpstops. Rear is good, front needs 2”. Ordered Rubicon Express front lower 2” kit, comes with pads that have a countersunk hole and self tapping bolts. Easier than hockey pucks.
I realized that the rear brake hose runs down the left upper link along with the locker hose and harness so only front need the extended hoses.
I see a little ATF slung from the Tcase rear output so I have a seal coming.
@Jody Treadway I measure 5v at the cruise on/off switch on one of the 2 wires. The switch is switching according to my multi-meter (random ohm readings but change when pressed) and I see resistors on the back of the switch. I assume depending on what button is pressed, a different signal is sent back to the PCM.
Would a good next step be to secure a scan tool somehow and see if the PCM shows the switch as working? If it doesn’t I would think clock spring. If it does maybe cruise servo.
I approve of this messageBrake hoses for the front are here. I also have 3” front lower bumpstops and 1” rear upper cup spacers.
I added an inch to what I needed so when I switch to 35s I have the room. It should have 5”+ up and more down.
As an occasional wheeler, I don’t want any more lift. It drives so nice and has zero bumpsteer or DW. Being able to cruise the parkway and backroads without drama are more important than ultimate wheel travel and I won’t be happy until it has 35s.
I’ll cut the front 3” lower bumps to 2” to use for now and save the extra inch for use later. Won’t install the rear til later.
Going to let @Chris_Keziah put 4:88s in it by fall.
ThisThe best answer is to have Oliver’s add a CV to my shaft and then tilt the pinion up with adjustable uppers (eventually all arms will be replaced or maybe the full long arm treatment)?
YesOnce I am ready for the TT, is the best answer to have Oliver’s add a CV to my shaft and then tilt the pinion up with adjustable uppers (eventually all arms will be replaced or maybe the full long arm treatment)?
So you’re saying tilt the axle down for now until new shaft and the BL/MML?.Reach out to @Chris_Keziah and see when you can get a quickie appointment with him and run down to his shop one evening (if he's willing) and get the rear adjusted
If you're not in the position to get upper and lower adjustable control arms to dial it in perfectly....then I (personally) would at LEAST get adjustable uppers so you have SOME sort of adjustment. But I'm no expert. I just stayed at a Po White Boy rental in Harlan with a few and tried to pick up as much as I could thru osmosis and contact highSo you’re saying tilt the axle down for now until new shaft and the BL/MML?
You forgot didntchaI'll drop a reply later on today when I'm not as tied up.
Na, got off work then proceeded to make 3 phone calls, cook dinner then worked in my shop till 11.You forgot didntcha
OK, have some questions for the brain trust.
My next plans for maybe this late fall/winter would be a 1.25 BL and 1” MML.
No real problems with this, I will do a cable Tcase shifter kit at the same time or possibly before.
Now to the questions.
I have a slight vibe already at times. The rear shaft is the factory flange type for the 241OR without a CV. With the springs and stock arms the pinion is pointed up a little compared to the output and this seems to be where my vibes are coming from.
It isn’t a terrible vibration but it is there and is cyclic. This would get better maybe with a MML but worse I’m sure with the following eventual tummy tuck.
I like to plan things a little ahead and look for holes long before I buy parts.
